Broke down with the sales going on and bought myself an early Christmas present. Already done with the shopping for the wife and daughter so figured why not. And I already have lca's and brackets, just need to decide on shocks/struts.
http://i907.photobucket.com/albums/a...ps9f92c225.png |
nice! and konis!
I'm still doing a little research on it, don't know if I want to switch to coilovers or not. Looks like plenty of guys are getting reasonable 60's with good shocks/struts.
BMR lowering springs
BMR Adjustable Panhard Bar BMR Panhard Bar Brace BMR LCA relocation Brackets BMR Poly LCAs BMR Adjustable Poly UCA and Mount Eibach camber bolts I guess I like BMR products :) Next upgrades coming when I have the cash, Konis, sway bars, and bumpsteer kit. |
Koni Yellow shocks/struts
Eibach Prokit springs Eibach front/rear sway bars J&M camber plates J&M rear LCA Considering adding: Watts link UCA LCA relocation brackets |
Re: Post your Suspension mods
Drag racing setup:
GT front springs V6 rear springs GT500 Strut Mounts Strange adj struts (set on 5 for street and 0 at the track) Strange adj shocks (set on 5 for the street and 2 at the track) GT500/Brembo LCAs BMR LCA relo brackets (set in top hole) Roush nonadj UCA and Mount Shelby rear sway bar JPC rear sway bar relo brackets No front sway bar BMR Lightweight radiator support front sway bar delete SPC adj panhard bar |
That's strong for an auto with a stock converter! Although, with 4.10s and a 4.17 1st gear, that's also a lot of mechanical leverage. Just curious, what tire is that? I'm assuming a 275/60 radial.
for the full list of mods: http://2011gtcs.weebly.com/ |
My setup:
Tokico D-Spec adjustable shocks and struts (currently set to 4.5 turns front, 4.75 turns rear) BMR SP009 springs GT500 strut mounts Eibach 1° camber bolts Freedom Racing Aluminum Dbl Adj PHB Next on the list will be LCAs or relo brackets. http://farm9.staticflickr.com/8108/8...2859fcef_b.jpg |
