Glad it is working out. Have you seen the updated version with arms that support the shifter assembly on the trans? Just as good, I'm sure better than a blowfish bracket with that.
I still get locked out going into 5th from 4th at 7800. Likely clutch not disengaging completely. McCloud rst will go in later when its time for a replacement with a lightweight. Flywheel. |
| All times are GMT -4. The time now is 09:22 PM. |
