[QUOTE=DirtyD;59118]Last I know is $320 for 3 tunes I think. Lope tune was an extra $50[/QUOTE
What are the differences in the tunes ? |
There is no reason to bash anyone or any company here, that's uncalled for, I run a safe bama tune, I'm sure an AED or another could get me another 5 to 10 horse, but not free like bama.. and I drive with my hood open all the time!!! Ace ventura style head out the window! All the kids are doing it these days... you guys make good points about the data logging tunes vs dyno but ... I'll have to test it out.. and I wasn't suggesting the other companies could see the other companies tune I'm suggesting they outright purchased one to compare that's all, 3 years ago I bet Lund and others that had inside info were better. But now they are all really close.
fordplay,
Ace Ventura style FTW!!! On a different note, if you purchase a tune from a company you cannot simply see the settings in the tune with the SCT dealer software as the file format is completely different. When you use the SCT software as a dealer or a proracer (as SCT calls it), you make your tune then you save it in one format and then must convert it into another to send to a customer thereby encrypting it. If you want to see what is in the tune file as a customer, you either have to have the dealer send you the tune file in the dealer format or you can try to datalog the car and you can start to make some educated guesses about what certain settings are based on what you see in the datalogs but you will not see what really is in the tune. |
Did he screw up the tune on your Miata? :blah: |
Is that when you knew you were gay? When you bought the Miata? |
Yager, so the tune is encrypted and you can't reverse engineer it??? Hmm mm interesting. .. modern tuning is black magic to me, I've never had the patience to program either so... and OG.. not to get involved in another person's argument. . But.. yes. Even on top you are!!! Ha ha
I'm literally LMAO over here. Good one |
I'd actually be very interested in someone that could take 2 tunes and compare them, maybe even in the same car, not just butt dyno, hell not even a real dyno, but someone that could say ok tune "x" employs a 900 rpm idle and a 25% advance throttle opening and so much torque management and tune "z" does 23 degree advance ... Etc. . You know? Like my steeda tune is great but very safe and I swear when I shift it takes away 50% throttle, the bama race tune is a monster, just shreds tires Alllllllllll the time but I swear when I get a bad tank of gas and I'm wot and shift I hear predetnation, the logs see nothing but I swear I hear it on bad gas, however the performance tune saves my tires and I think has a touch of torque management in there.. and other tunes are all in the middle. But I could be wrong on everything???
Brent you need hood struts!
They are on my Christmas list along with a new radiator shield that the current hood prop has scratched up ;)
I'm new here. I've had AED tunes since 7/13. Performance Tune and Drag Tune are the same except on the Drag the nannies are disabled. I also have the Lopey.
Absolutely worth effort. I like to run at the TMS Friday Night Drags. After getting the Tunes from Shaun and adding MT ET II's DR's. My car was completely different. Shaun is also great at customer service. A couple of things that I learned along the way about SCT/Tuning, etc. (if this has been posted before than forgive me for redundancy) 1. Get a 2 amp trickle charger There is something that can cause voltage to change during the downloading in the 2011+ 5.0's. (SCT tech told me) 2. Always retune at home and make sure auto/lamps and all acc are off. I had an issue with pump gas from this area. Shaun said he had a few guys in Texas that he had the same experience with. I just use Shell 93 now. As good as the Tune is; I'm still looking at Whipple 2.9!!! |
I think I've seen you driving around the Trophy Club / Roanoke area! :) |
Your car sounds great. I was at Roanoke Rd/170 when you went by. |
My son-in-law has CTS V (800+ rwhp) and he maxed out at 196 ( I think; have to verify) ps Im also looking at VMP, Roush, etc… |
Yager: I've seen your Youtube also. Very impressive. Thanks for info. |
Another guy Cliff Elliot, he has been there every year I've been going, his 2011 GT/CS auto ran 144.0/169.2 this year. Fairly typical bolt on car, I know it has a Boss intake, and I think headers. Cliff and I have both outrun a lot of blown and nitrous 2011+ cars and GT500s out there. I think the big thing is reduce drag as much as possible. Anything that sticks out on a side, or up, or hangs down underneath is just slowing the car down. I don't have any rear spoiler, no GT/CS fascia or splitters on the front end, it is just a stock GT front end. I take the mirrors off, and I cover the front end of the car in Road Wrap so no air gets through the grille or the lower opening. That's it, no tape all over the car like you'll see some doing out there. This car certainly doesn't look like it runs 180, but I spend my money making it faster, not on "look at me" crap. https://scontent-b-dfw.xx.fbcdn.net/...84948640_n.jpg https://scontent-a-dfw.xx.fbcdn.net/...33506649_n.jpg |
Kdanner,
Nice car and great times. I really like the look; simply fast. I like your 1/4 et. What mods? I went to The Mile for the experience of it. Not sure when I'll run it again. |
Congrats on the run, 180 is very impressive in the mile. Also very impressive you are doing that NA and whooping up on some blown cars. Always enjoyed seeing your NA setup put a hurting on the tracks. Are you using stock cams, or anything aftermarket? -Alex |
damn 180 in the mile is fuckin smokin.. I've never done the mile before so excuse my ignorance,lol Is blocking off all the air cooling the radiator safe? I imagine if you where making 700-800hp it'd probably cause the engine to blow or risk detonation? I'd like to try the texas mile eventually but doubt I'd come anywhere close to your numbers.
I'd be happy with 160 though :) |
There's a lot of time to wait before you run so the engine is cool. I've never seen more than 212 water temp at the end of a run. |
