Trust me, it will be close, but you won't win. Your gears just won't let you. |
Exactly how do you think that would be worse? A car with 3.73s would edge out a car with 3.55s |
Depends on where my friend. On the hwy it's a different story. Ask me how I know.
oh and good races. |
For every shift he loses momentum. The higher geared car stays in gear longer makes a diff.
I'm applying this to the fact that they both have the same mods, and are running the same tires. Yeah, I know I haven't raced much, I'm not trying to prove that. But if you have two cars that are basically the same mods, same power level, same tune, etc, and the only difference is gears and driver, it's a pretty good guarantee they 3.73 car will take the advantage over the 3.31 car, starting at the same speed, because the 3.73 car will have the ability to reach the shift points at a sooner time. I don't really understand the argument on shifting. If you know what you're doing, you aren't taking your sweet time rowing gears in a race, so shifting is negated, as I said before, since the ground that is gained when the other shifts is lost as soon as you shift.
Lol just stop. You need more seat time to learn and put down the calculator.
I can't afford (time and money) to hit the track every weekend to, especially when the nearest track worth racing on is about 1 hour away. Call me a bench racer. IDGAFFMF! All I'm doing is using the fact and information currently available to me to form an opinion. |
