Stock tire size on my '12 was nearly 28" tall. I run 295/55's which are about the same height as stock. Car came equipped with 3.55's from the factory. I cross the traps at 7200 in 4th (MT82). 28" works quite well with 3.55's.
Mine was shifting into 4th right before the finish line with my 3.15's. It short shifted at 7000. I think I can avoid this shift all together if I just raise the 3-4 shift point. This SHOULD cut some ET as well since I'm removing a shift. Right? Not sure how much though.
28" tire and just make more power.
A 26" tire would basically give me 118-119 MPH at 7200 RPM redline I think a 26" tire height is my best bet for the power level I will have my car at for a long while before boost. I should never trap more than 118-119 if I'm around 420-430 rwhp (after E85 conversion and maybe a TB). Right? |
I'm right at the stock rev limiter in fourth gear when crossing the quarter mile.
3.73s 28.5" tall tire (305/35-20) 114.5mph Quote:
But yes, in perfect math/conditions, a 27" tire would but me basically at 120 at 7000 RPM. 120 MPH should be a low-mid 11 sec pass, correct? |
Mine has crossed the line at 7200 since day one, naturally aspirated at 115 mph and blown at 130 mph. Gearing is gearing.
If you're buying a dedicated drag wheel/tire setup, get the 28s. They will work fine with your n/a combo and give you room to grow.
It doesn't really matter. We're all slow. :D
My 20s and 3.73's are ideal for drag racing for sure.
about as much as my 19's and 3.15's.
