-   -   DFW tuners (http://www.dfw50s.com/showthread.php?t=4568)
ShortBus 09-17-2014 09:18 PM
And I'll bet going to fuck up there white Boss at RR. Just putting that out there now.
slim87gt 09-17-2014 09:24 PM
Originally Posted by Taxman (Post 74753)
No he's got Daniel from Triangle Speed Shop in Houston remote tuning.
This is some what true. I do some of my own tuning and I also use Daniel from triangle speed. Daniel is an awesome guy to work with and knows his stuff.
downtime! 09-17-2014 09:38 PM
Originally Posted by Midnight11 (Post 74773)
Steve wants everything in his favor. I just asked you if you want to since you were doing all this talk
Didn't you get drug, twice, by a N/A catfish at the track rental? Are you sure you want to be calling anyone out?
Midnight11 09-17-2014 09:54 PM
Donnie is the king of bitching and moaning
downtime! 09-17-2014 09:56 PM
Originally Posted by DR281 (Post 74795)
Wow!
There is definately two sides to every story!
Downtime, you were never put off or made to leave or avoided. It was the opposite. I jumped in your car as soon as you would arrive to try to find your complaints. Numerous times you drove the car and said it was good then later had an issue. I went for a ride with you and you said it was good and couldn't make the car act up.
I don't claim to be perfect or the only one capable of tuning a car. However if something is not right I will put in as much time is necesary to make it right. So to say you were avoided is a flat out lie.
There are no injectors designed for returnless or return so that's another lie. There are tons of boost a pumps that are wired up to run all the time with no issue. That does not cause a problem.
You knowingly bought used parts so don't make it seem like we put used parts on your car when you thought they were new.
I am sorry it didn't turn out the way you wanted but you drove and raced the car across the country without issues.
If the other shop made it so perfect for you, why did you make it back to stock?
Again I am sorry it didn't turn out the way you thought or you weren't happy. However we would have done whatever necesary to make it right. No corners cut!
The only used part I knowingly bought was the blower itself, it had been on the gold car for a couple of months, we both knew that. Everything else was supposed to be new, according to your words. The boost a pump didn't even have end caps on it, just wires sticking out that had been hack spliced into the fuel pump harness and not even soldered. Same goes for the wires up front on the MAF harness. Twisted and taped, no solder. Didn't use the template for the cold air kit, fit like shit, had to cut the inner fender liner to get everything to fit right. Wood screw holding the cold air pipe to the fender, that was tightened down so much it stripped the hole and just spun. Yeah, I made all that stuff up.
And yes, the car ran great at the track, but what I asked for was "drives like stock, just more of it", I believe I even went on at length about not wanting to mess with the way it delivered the power. Your words to me? No problem, we can do that.
As to not running me off, what choice did you leave me? Brad would "forget" to call me back every time I called. When I called back, and got through, it was always the "shop is busy" excuse. I tried to hit him up on FB when I had had enough and was ready to take everything off, and it took him 2 weeks to give me an answer after he said he'd get right back to me.
That's why the car ended up back with Travis. The look on his face when he saw the work was classic.
It was clear that y'all had had enough of me and my business, and had no intentions of ever making it right. If y'all had done things right, we wouldn't be having this conversation now would we?
BLK2012GT 09-17-2014 10:06 PM
This has to be a first, really bitching about Hpp work and thinking Gearheads does good work? Wtf
DR281 09-17-2014 10:19 PM
What's weird is when you came to our shop, you were bashing ghp in the same way. Maybe you were in search of some mythical creature. Some people you can try as hard as you can but you just can't please. I would have loved to see that. Nobody just twist wires together & tapes them. Sorry not buying it. The inner fender must be trimmed for the 4.5" tube. I don't buy the wood screw either. We don't have any of those up there. Maybe they made a special trip just for you. Again sorry you weren't satisfied. Like I said I tried & would have kept trying. When me & you went for a ride you said it was good & couldn't make it do anything you have described. Good luck to you. Keep bashing away about something that happened over 2 years ago. I'm out just wanted to put out the other side.
62nalide 09-17-2014 10:23 PM
I still wanna play heads up in the 1/8
With my NA 5th gen
blownaltered 09-17-2014 11:17 PM
I believe it's been you crying like a little school girl. I could give a shit less about who takes their car where. Keep up the bitching this is the most action this site has seen in a year.
Midnight11 09-17-2014 11:22 PM
You and Steve need a room lol
Good to see you both out at the track day or any meets. You just before to whine from
Behind the keyboard
downtime! 09-17-2014 11:27 PM
If you remember when I came in, the only thing about GHP I was pissed about was the guy in the front office (I never can remember his name) that took all the information down for the Fox project, and said he'd call me back with prices that afternoon, and 3 weeks later I still hadn't heard anything from him. Exactly why I initially gave Brad such high praise, since he called me everyday with updates in the beginning. I never said anything bad about Travis, and never will. He's fixed jacked up work from other shops for me more than once, including yours. He had the car for two weeks, but when I got it back it idled normally, didn't die at redlights and basically ran just like I wanted it to originally.
And you don't have to buy anything. Myself, Frank Rodriguez (we used his shop) and Jonathan Kelley were all present when we took her back to stock. We couldn't believe the amount of hack work done. The best part of the whole deal was the fact that when Brad did finally get back to em to give me the estimate for removing the blower, the number was $1200. If I calculate correctly, that comes out to about 15 hours of labor. In 10 hours, we had the long tubes off and installed on another car, the blower off of my car, and about 80 % installed on Jonathan's car. All without the benefit of the manual that I asked for from y'all but never received. I paid for everything in the box, did I not?
In all the time that has passed, I had never said one word bad about the shop. My worst comments were "I got 90% of what you promised me" and "yes, he can tune cars, just couldn't tune mine". It was only after seeing the "quality" of the work that I stopped caring.
It's funny too, thinking back on getting started in modular cars. All I ever wanted was a car done by HPP. Everyone that was anyone back then was singing the praises. My first projects weren't "cool" enough for y'all (Procharged 2V car, nitrous 4.0 6 cylinder car, etc.) to even talk to me about back then. I brought the 4.0 car up when y'all were still in the old building and couldn't get the time of day from anyone there. We did manage to get it on the dyno for some baseline runs, but that's as far it went.
What I learned from all this is to be careful what you wish for, since it just might come true, and you might not necessarily be happy with the results.
Anyway, it's all water under the bridge now. Y'all didn't care enough to keep me in the first place, you wouldn't make the effort now, and even if you did try, what is my incentive to think the quality of the work done would be any better now than then? I'm done with new cars anyway, having too much fun with the old Mopars again.
downtime! 09-17-2014 11:28 PM
And my mistake on the wood screw, it was actually a sheet metal screw. The type that holds siding on a metal building. Still had the rubber washer on it too.
DirtyD 09-17-2014 11:30 PM
This is cool to hear.
downtime! 09-17-2014 11:32 PM
Travis has never let me down. He's tuned a number of cars for me over the years, and fixed what other shops haven't been able to as well. I'll admit, he's had his fair share of questionable shop help, but as far as his work goes, it's always been good. If he has a tuning flaw, and they all do, it's that he tends to tune things very conservatively, leaving a lot of power on the table. And I completely understand why he does that.
BlackStang08 09-17-2014 11:38 PM
Speaking of true street, anyone read their latest google review? A person posted his entire story on there. Short story, TS raked them over the coals and blew up their car. It's a 5.0, might be a member on here?
Midnight11 09-17-2014 11:42 PM
Link?
BlackStang08 09-17-2014 11:46 PM
I'm on my phone and it doesn't show me the link. Just goto google.com. Type in true street motorsports and look at the reviews. It's the one from two months ago. He even tells you how much he spent.
Midnight11 09-17-2014 11:49 PM
Oh yea that was Brandon's car. It has also been sold already lol
DirtyD 09-17-2014 11:50 PM
And now he owns a GM....
BlackStang08 09-17-2014 11:51 PM
Wow, lol. I felt bad for the guy, reading it.
62nalide 09-18-2014 12:12 AM
Damn that sucks
Grandpa 09-18-2014 12:25 AM
What a traitor!!!
DirtyD 09-18-2014 12:27 AM
Originally Posted by Grandpa (Post 74862)
What a traitor!!!
Why are you still awake? I didn't think it was possible for old people to stay up past double digit times?
blownaltered 09-18-2014 12:28 AM
He's old so he takes naps during the day.
blownaltered 09-18-2014 12:33 AM
Behind the keyboard
What do I need to go to the track for. I drive a vert, I would have to put a cage in it to run. I'm not doing that to this car. I used to race every weekend at the track. My times in the quarter were faster than your times in the 1/8th lol. If I had a 700 hp car that ran damn near 8s in the 1/8th I would fucking kill myself.
As for Friday night meets I never see you there. I make it out to at least 2 a month and sometimes more. I have a wife and two kids. Sorry I have more important thing to do.
Grandpa 09-18-2014 12:40 AM
Its the only time I can get my running in is after the kiddos are in bed. Lol
Fuuck. I SO wish I could nap during the day!! I think I have better odds of winning the powerball than getting two little ones to nap at the same time so I could too. Haha.
DirtyD 09-18-2014 12:45 AM
he's old so he takes naps during the day.
lol
DirtyD 09-18-2014 12:46 AM
It's called benadryl. Double dose.
But I can understand the running part. It's also cooler when the sun is gone.
Grandpa 09-18-2014 12:49 AM
Behind the keyboard
I've kinda had a rough year bro. I'm pretty sure I should get a pass on the last 16 months for car stuff not being so important. Family comes first.
Besides, you gotta post stuff up or gimme a text to let me know whats going on. I'm not online as much anymore these days.
Grandpa 09-18-2014 12:52 AM
His car was down for awhile. Before that he had bad tires and made excuses about racing me. Now he makes a bunch more power and feels froggy to pick on everyone. I aint skuured though. :favorites37:
Midnight11 09-18-2014 06:33 AM
If I had vanilla ices car I'd kill myself too
Midnight11 09-18-2014 06:35 AM
http://i96.photobucket.com/albums/l1...psw30kjjes.jpg
When I read your post this is all I thought of Donnie
BLK2012GT 09-18-2014 07:40 AM
Shit, David and I got fucked worst.
J.Shoot 09-18-2014 07:44 AM
ok.....
I very seriously doubt that.... but whatever. I'll be looking forward to it.
I'll also be at Ennis on Nov. 1st. Why don't you come out then as well.....
J.Shoot
blownaltered 09-18-2014 08:06 AM
Your right I should off myself because I have one of the cleanest fox bodies in town. I get people every time I drive the car giving me thumbs up and make offers to buy it. You have a black coyote that looks like every other car that nobody gives a shit about and now you make power, so now your cool. But when you run 7.8, I have you tell you your not cool. Your slow and people point and laugh
blownaltered 09-18-2014 08:08 AM
Funny pic. I was actually fast through most of the 2000s. I'll admit I used to be fast but that's better than you because you have never been fast. At least I have done it.
ShortBus 09-18-2014 08:17 AM
You seriously doubt that? Lol let's see same car with more power? Hmm, shouldn't be that hard to see why? Sure I'll come out to any 1/4 and run you as soon as you agree to come to a track and race around some turns. Would never happen bc you have bastsrdizes you car from something that handles very well to a straight line car. Cool if that's your thing but not mine. If you notice I said I'll drag that thing from a roll race. Shouldn't be to hard to get me from a dead stop with a th400 lol
ShortBus 09-18-2014 08:19 AM
Taken the car apart right now should have it back together right around nov. 1st. I'll be looking for you at Coit around then or RR.
Midnight11 09-18-2014 08:26 AM
Haha keep telling your self that big guy ;)
Midnight11 09-18-2014 08:35 AM
Cool story bro I didn't have a license back then
