Introducing the Type-AR Carbon Fiber Package from Anderson Composites
3 Attachment(s)
Introducing the Type AR carbon fiber appearance package for your Ford Mustang. The kit is meticulously designed and carefully crafted by Anderson Composites, a well-known manufacturer of carbon fiber and fiberglass custom body parts for domestic muscle cars. The package includes the front chin splitter. As the name suggests, it splits the oncoming air stream apart preventing it from creating a high-pressure area underneath the car, which otherwise creates lifting power thus reducing traction at high speed. The same goes for side rocker panel splitters. They prevent the air from the sides from going underneath the car. Also, the kit includes the rear diffuser which reduces the turbulence effect by smoothing out the fast-moving airflow from underneath and its transition into the ambient atmosphere. The resulting effect improves the car’s aerodynamic properties and creates additional downforce. Anderson Composites® - Type-AR Style Carbon Fiber Front Chin Splitter at CARiD.com https://www.carid.com/images/for-for...u-ar-wf-02.jpg http://dfw50s.com/attachment.php?att...1&d=1570544677 Notes: Mounts with OE hardware (not included) For correct fitment, your Mustang will need to be a performance package belly pan (splash guard) Bumper must be removed for installation Material: carbon fiber (1 piece) Anderson Composites® - Type-AR Style Carbon Fiber Quad Tip Rear Diffuser at CARiD.com https://www.carid.com/images/for-for...u-ar-wf-02.jpg http://dfw50s.com/attachment.php?att...1&d=1570544677 Notes: Mounts with OE hardware Requires rear bumper removal for best installation results Mounting tabs may require modifications for correct fitment Minor adjustments may be necessary as part of the normal installation process Additional clips and hardware may be required to optimize installation Material: carbon fiber (1 piece) Anderson Composites® - Type-AR Style Carbon Fiber Side Rocker Panel Splitters at CARiD.com https://www.carid.com/images/for-for...u-ar-wf-02.jpg http://dfw50s.com/attachment.php?att...1&d=1570544677 Notes: Mounts with OE hardware (not included) Reduced lift adds stabilization to the car during high-speed track driving and improves traction Does not include two (2) replacement ¼” x ½” rivets (drill and rivet tool required) Material: carbon fiber (1 pair) Fitment: The package fits 2018-2019 Ford Mustang All these components are also available in more affordable unpainted fiberglass variants. If you have any questions or suggestions, feel free to contact us in this thread, personal messages, Live Chat at CARiD.com or call 800.505.3274 (toll free) |
