-   -   Whiteline relocation bracket (http://www.dfw50s.com/showthread.php?t=1095)
cars12369 02-05-2013 12:39 AM
Hey just curious if anyone else was running these i need a pair of relocation bracket looking for good deal on them could get for 90 new
merlinmol 02-05-2013 01:27 AM
I run Whiteline products on mine, including the brackets.
cars12369 02-05-2013 02:43 AM
did you do it all at once? the suspension i have the eibach pro kit full full adj sway bar with j&m extreme control arm i spin bad off the line.
merlinmol 02-05-2013 03:55 PM
Yes, everything was done at once, as far as spinning, what other mods have you done?
cars12369 02-05-2013 04:37 PM
alot if i launch at 1800 rpm tires spin all the way to 50
Borla catback s-type Borla Long tube off road x pipe
Jlt carbon fiber intake 3.73 gears
pro kit Eibach adj sway bars
J&M panhard bar J&M extreme lower control arm
koni STR.T RTR wheels NT555
DSS Aluminum 3.5
BBK TB
JDBishopArts 02-05-2013 05:15 PM
You need better tires number 1. Or tires with a thicker sidewall if you're drag racing. These cars make enough power to spin any low profile tire. Number 2 the relocation brackets will help plant the car a little better but won't help your spinning issue. They are mainly used to help get rid of the pesky wheel hop. I have the BMR relocation brackets. Got them from jayman at hypermotive. Very good vendor on here.
downtime! 02-05-2013 05:31 PM
+1 on the tires. You need a good set of DR's to launch these cars without spinning. Sidewall height is a big deal as well. Running a 60 series tire, I ran 12.0 at 116 lifting the front end, with a 50 series tires more of the same, then changed over to a 17" DR with a 45 series and it was spin city all over again. My new set is 325/50-15's, should hook like a monster with the new power!
cars12369 02-05-2013 06:04 PM
I thought the Nitto NT555 were good tires im mostly looking for street use
JDBishopArts 02-05-2013 07:33 PM
They are ok/good at best handling tires. Horrible launching tires. I'd go with the NT05 or NT05R if you're looking for a decent DR. Only downside is bad lifespan. Very bad lifespan.
cars12369 02-05-2013 10:08 PM
Yah thats why i also went with the nt555 great wear what do you guys think about the Nitto INVO
DirtyD 02-05-2013 10:17 PM
I've heard nothing but good about it
cars12369 02-05-2013 10:26 PM
I think those will be my next set i have plenty of tread on my nt555 over 10k miles on them
JDBishopArts 02-05-2013 11:09 PM
The invos are going to be what I put on the Vossens. They still aren't a good launching car. They are a VERY good handling and road course tire.
cars12369 02-05-2013 11:18 PM
Hmm well i might just have to give it a shot heard good things about them
merlinmol 02-06-2013 01:07 PM
I love the Michelin Pilot Super Sports that I have on my car, they are also for road courses.
