Injector Question
Will these http://www.americanmuscle.com/mustan...injectors.html
or these http://www.americanmuscle.com/mustan...injectors.html fit in the new 5.0s? if so ima get them ASAP |
What intake do you have? The gt500's dont work with the Boss intake without extensions. I never tried my in the stock intake but i assume they are to short for it as well.
I just have the stock 5.0 intake.......so should the EV6 ones work?
Bump
I can't add a lot to this thread other than to say that I believe you have to confirm that both the connector as well as the length are the same. I've seen some spacers that fix the length issue, but am unsure on which connector is correct. My .01.
I used the 80lb ev6s on my car. I beleive the 47s are the same length.
Call TrueStreet in McKinney. They are a sponsor here, but they also do great work and are extremely helpful over the phone.
Re: Injector Question
Ev6 47lb from Ford Racing fit perfect with my Boss intake
Ok so it should work fine with the stock manifold then right?
Yep!
| All times are GMT -4. The time now is 11:50 PM. |
