-   Terminators (http://www.dfw50s.com/forumdisplay.php?f=44)
-   -   Your Setup (http://www.dfw50s.com/showthread.php?t=1119)
Bearded Banger 02-08-2013 01:21 PM
Your Setup
Lets get a What you are running Thread going:
2.8 KB with 3.1 pulley, stock lower
Still Returnless, E85, Division X rails, 80lb injectors, dual FPDMS, GT Pumps, BAP, Fore Hat, tuned by 04Sleeper
Basic Boltons: Division X Idlers, JLT Intake
Making 720hp/689tq
What you got?
Emwun Garand 02-08-2013 03:19 PM
Basics
3.3L Lysholm, 3.5" pulley, stock lower, custom blower cams, Fox Lake Stage III heads. 21psi
Kooks 1-7/8" long tubes, off road x, 3" MAC catback
Return style, E85, Lysholm rails, 105lb injectors, 3x Walbro GSS342 pumps, Fore hat, BAP
Division X idlers, Vortech 5" intake and wide mouth throttle body, gt500 maf, a whole bunch of non performance stuff
817/687
fha8388 02-08-2013 04:14 PM
2.2 kb. 2.76 upper stock lower
Jlt next gen intake
80s , kb bap, gt pumps, stock hat , returnless e85
650hp, 540 ft lbs. Hpp tuned.
Gona get 04 sleeper to tune it soon:burnout:
aCid 02-09-2013 03:10 PM
Have all the shit just haven't put it on yet.
2.4 Polished KB with 3.5 Pulley
Lethal Performance Budget Return Style Fuel system
60lbs Inj.
BBK LT's / No-Cat BBK X-pipe / Bassani exhaust
JLT Carbon Fiber Intake
Right now with my current set up I'm putting down 460/480
Eaglei532 02-10-2013 02:51 AM
2.3L Gen 2 Whipple 3.3'' pulley, 4 Lb Metco Lower
GT pumps, Fore Hat, Dual FPDM, BAP, Tuned to 93
Basic Boltons: Bassani Mids, Bassani X, Bassani CB, BF Idlers, Accufab SBTB, JLT RAI, MGW shifter, STOCK SPRINGS, STOCK REAR(with BF brace) 305 555R DR,
Making ???hp/???tq. Couldn't even tell you the car needs a dyno but it needs a clutch before that sooo. I would venture about 580/535, but again I dont know yet
Stangmaster281 02-11-2013 09:11 PM
whoops nevermind, I wasn't sure if u got my pm. lol
Modfox 02-11-2013 10:27 PM
Stock long block 2.3 TVS 19psi, return style fuel system, ID1000's,E85, kooks 1 5/8 headers,677/606
Tuned by 04sleeper
Grandpa 02-11-2013 10:52 PM
I know Foofinator's set up is pretty much -
Teksid blocked 302 stroker
ported heads
longtubes
3.08 gears
3.4 Whipple
custom cooler in the trunk
E85 tune
low boost near 800rw
blownaltered 02-12-2013 06:58 PM
ported heads
longtubes
3.08 gears
3.4 Whipple
E85 tune
So does he have tubes going through the interior of the car or is it underneath?
Bearded Banger 06-07-2013 09:14 AM
Your Setup
Small update. Have Kooks Headers, Custom 3" X-pipe (purchased from Emwum Garand, had all ceramic coated black) and 3" Polished Bassani cat back system just about ready to go on.
*waiting for the heat to hit before install so I can watch Eric sweat his balls off
Bearded Banger 06-07-2013 09:15 AM
Your Setup
Next will be fuel system and more boooooosssssttttt!
03MachMe 06-07-2013 09:47 AM
Are those new tires any good at putting your power down?
Bearded Banger 06-07-2013 12:36 PM
Your Setup
Once I heat them up. Yes much better.
Austin@BA-Speed 06-07-2013 09:16 PM
2003 Sonic Blue 110k+ miles
Fluidyne Radiator and Gords HE w/ dual fans
Girggs Tubular K-Member and lower front control arms
MM Front and rear coilover kit with bumsteer kit
MM Steering Shaft
Full Length Subframes
IRS bushing and stage 5 axles
McCleod RXT Twin Disc
StopTec Slotted Rotors
Not worth mentioning power mods, its a true slowbra with an Eaton, but it sounds damn good
Plans for a whipple or TVS in a year or two
WOMACK03 08-26-2013 06:45 PM
Making 720hp/689tq
What you got?
Your fuel system soon......:Caffeine:
