Koni Yellows
Where do people set these for DDD? (daily-duty dampening?) I set them at full firm minus one full rotation and they're still pretty damn firm! The drive to work was awesome, but still a bit stiff.
Thanks for the feedback everyone... :D I think I'm gonna just set them at full soft unlessI have a good reason to stiffen them up. Firmer than stock but not crazy like if you ratchet them down.
If I had some Konis I would post my opinion. Just toy with it and see what you like.
I'm running half turn down from full on boner stiff
set the fronts to 80% and the rears to 65%.
Doug, Toby, etc.. ya'll should come out to ECR this weekend to test out your Konis! Check the Events section for more info. I need some other stangs to compare to out there.
Just bought Koni Yellows. I'm going to toy the hell out of em!
I do 1/4 turn from full soft on all 4 corners. The stiffer setting is nice for flat roads, but as soon as you hit bumps, dips, etc... you regret that setting. I drive a lot with this softer setting, and I enjoy my car much more being able to float over the rough stuff.
I do the same 1/4 turn from full soft is just a touch stiffer than stock and rides nice
| All times are GMT -4. The time now is 09:54 PM. |
