1987 - 1993 Ford Mustang (excluding Convertible Models) Window Sweep 4 Piece Set
CHECK HERE FOR PRICES 1987 - 1993 Ford Mustang (excluding Convertible Models) Window Sweep 4 Piece Set
FREE SHIPPING ON ALL PARTS!!! http://static.1aautoimages.com/parti...00197/main.JPG This inner and outer window sweep set(window felt) is the highest quality available. These are the strips that attaches to the tops of the doors and "sweep" the window as they go up and down. Also known as glass sealing strips. Features: Sold as a 4 piece set Fits Sedan & hatchback models Secures to inner door panel Direct replacement Prevent damaging water and debris from entering the door Not correct for convertible models If your window sweeps are cracked and allowing the elements into your door, this is for you This part replaces: OE #: E8ZZ6121453A,E8ZZ6121452A,E3ZZ |
| All times are GMT -4. The time now is 03:50 AM. |
