Intermittent Grinding 5th Gear?.....
I'm curious if anyone else has experienced this issue with an M6 car? Mine is an early build 13'...completely stock, daily driver. I've got around 7k miles on it now, and for about the past 1500-2000 I've noticed an intermittent grind shifting into 5th gear....just driving it normal down the road. I've never shifted the car hard into 5th, or really any gear for that matter, and it seems this occurs perhaps even when I'm shifting up into 5th slower than normal....not like when running up through the gears getting onto the hwy, but instead like when you are just putting it up there at slower speeds on city streets. It's very intermittent and at first I thought it was just me being lazy on the clutch pedal, but now that I'm paying more attention to it I know it's not that. My wife came in recently and asked me about it too....apparently it happened to her a couple times when she last drove my car.
I found mention of it in 11/12's here, but nothing on 13's - http://mustangforums.com/articles/in...estigation.php It also seems that 5th gear is a bit more notchy feeling than the others...especially when it's cold. |
im sure your car has upgraded fluid, but you may ask your dealer about this.
I haven't had any issues with 5th however I think my car has seen a total of 5 mins of 5th gear the entire time I've owned it. I never use the gear. Changing the fluid might be something To consider. I am running Amsoil's tranny fluid and it definitely made an improvement in shifting smoothness. The fluid however does not like the cold much but once warmed up its butter smooth!
That sucks man, keep an eye on it and start listening for any other new noises. Does it seem to have any dependence on the engine rev's or temperature, or just anytime now?
bad synchro. probably should take it in.
My car has the supercharger whine in 1-4th. Taking it in sometime this wk.
My 2011 5.0 with MT82 had the whine in 1-4 too. The input shaft bearing and race was going bad and eating itself, therefore spinning that metal through the transmission and slowly eating everything else within. Ford replaced my entire transmission with a new one at 20k miles. If you have plenty of miles left under warranty, you may be better off waiting longer until it gets worse, if you get my drift... |
The problem with taking it in is that the issue is so intermittent that I know they are going to just say they can't duplicate the problem.
Sorry man....first thing that came to mind! :) http://24.media.tumblr.com/tumblr_m3...0o1_r2_500.png |
| All times are GMT -4. The time now is 12:40 AM. |
