catback fitment issues
When I installed my catback everything went smoothly. I had access to a lift. I made sure everything was fit up nice and then tightened everything down. The tips were centered and spaced evenly ...etc. After about 2 weeks of driving I have notices the passenger side tip has moved in and rubs the rear bumper (see pictures) I have loosed the connection, moved it, re-tightened it while holding it where I want and it stays. However, after driving to work and back the next day it has moved back over.
Has anyone had this issue? Also do your tips stick this far out? |
Are you using an impact or hand tightening? Mine moved a little because of bottoming out, we re-adjusted everything then put spot welds in place, but it shouldn't be moving if you don't hit like i was.
Also, I wanna hear your car at some point when we have a meet. I have only heard the borla's on bad videos or the v6's. |
Hand tightening.
I usually can tighten more than my impact....I can go back over every bolt with a torque wrench if anyone knows the torque values these need. |
Re: 2013 gt: Borla s-type catback fitment issues
Yea all the aftermarket tips stick out on the 13 due to the difference in bumpers from the 11-12, some more than others. A boss rear valence helps them from looking so out of place. As for the pipes moving I wish I could help you there
I might just need to put it back on the lift... loosen every single bolt..re-position it all and re-tighten. It will probably hold/stay in place better now that it as been through enough heat cycles.
Here is a picture of the tips right after I finished installing.
http://i82.photobucket.com/albums/j2...ps22984237.jpg |
I have the same catback and love it! Sound is amazing! However I too have had some headaches with getting the pipes aligned. I would suggest looking at the pipes coming from the cats back to the axles. Make sure those are where they should be and the clamps are TIGHT! I had a recent issue where I had to take off the driver side pipe to work on my UCA. I accidently got the middle section pipes twisted a bit too much and it caused the muffler section to move. I would suggest to try and move around the pipes in the middle as well and make sure those are super tight. With this catback there are 6 total clamps you have to make sure are super tight to prevent it from shifting. Having a friend hold things in place is always helpful too.
Ya its a bit of a pain because you have extra piping to deal with you normally don't have with just an axle back. It will just take some messing with. I played with mine a lot when I first got it to eliminate leaks / alignment issues.
Had the same issue, until I deleted the resonators and had pipe welded up.. Now they're perfect and haven't moved at all in 5k miles..
Didn't read all the posts, but I will say I wasn't impressed with the out of the box fitment on a set of borla ataks I installed on a buddies car. The hangers didn't line up at all to the stock location, and I had to do a lot of bending and manipulating to get them on and lined up right. Still didn't go on perfectly, but we ran out of daylight
I never had any issues with the locations of the mounting hardware. My main issues were with getting all the pipes aligned and that comes with really any exhaust system that has multiple pieces. Doing it on a garage floor makes it much more difficult as well.
Borla is giving me a new passenger muffler under warranty. He claims it is caused by the flare on the pipe that meets the over axle tube being out of tolerance causing the clamp to loosen when heated.
He just emailed me this as well....looks like I will be getting more than just the passenger muffler!!!
"One last question. We have just released a new set up for your ’13 Mustang that will actually pull the tips in a little tighter. Is this something that you would like or do you like the tips sticking out a little like you already have. Let me know and I will finish this up for you today." I really like when companies have good customer service! |
| All times are GMT -4. The time now is 10:35 PM. |
