Clutch help
I have been tracking (1/8 mile) my car and last the last couple of times noticed some problems getting the car in third gear if I take the car to redline. I was running out of chances to run so I lowered my shift point to 6,000 and it went into 3rd fine. Do you think it's the transmission locking me out because I'm to close to redline? What is the fix, shift lower rpm or new clutch????
Thanks J.Shoot |
Re: Clutch help
There has been a number of people with this problem with the mt82. Check svtperformance there are some threads on it. Think one option is just to change the fluid, another would be an aftermarket shifter like Barton or mgw. I would do those before new clutch
From what I've read, the consensus is shifter AND fluid. I haven't looked into it too deeply though, I've got a 6R80.
BTW, what kind of times are you running, your car is making some good power.
Re: Clutch help
I would definitely change the fluid. If that does not help then look into a better clutch. At your power level and as much as you track it, a clutch will be very beneficial. If I remember correctly we installed an mgw shifter in this car.
Also if you plan to track it often I would highly suggest flushing the brake system and the clutch fluid with motul 600 fluid as they both share the same canister.
Changes so far.
I have changed to the MGW shifter already and changed the fluid last week, so no change.
My best time is a 7.11 @ 99 mph. I was launching at 4,000 rpm and hooking good. I tried to increase my launch rpm to 5,000 and the car breaks loose. I'm running 15" wheels with MT ET streets with 14-15 psi. I'm going to go back to 4,000. Maybe work up a little if it will hold. |
I called the dealership where I bought it, they sound very willing to help and they no my car has been heavily modded.
Need to change the clutch also I think. J.Shoot |
| All times are GMT -4. The time now is 01:53 AM. |
