Gear whine on 3.73s
Hey guys I got some gears installed around February. Ever since I got them, there would be a gear whine when I deaccerlerated from 50mph-40. It doesnt make any other sounds other than just part of gear. Could anyone help me out and tell me what make it whine? I thought if I gave it a couple months so the gears could break in, it would go away? But I was wrong :suicide:
What brand gears, who installed them, and did they use friction modifier
Oh, well if it's TrueStreet just give them a shout on here, I'm sure they'll answer any questions you have.
So it only does it decelerating from 50-40? is there a specific gear it does it in or any time any gear from 50-40 mph?
Btw yes we used ford friction modifier along with royal purple 75-90 gear oil in all of our gear installs. |
How soon can you bring it by for us to take a look at it?
Clint |
sounds like a transmission problem, not a rear end gear problem. If it was a rear end gear issue, the whine would likely be present all the time.
75w90 gear oil...? I'm pretty sure these cars call for 75w-140 gear oil specifically to quiet down the gear noises associated with 3.73 and numerically higher ratio's.
Also, some shops or mechanics will try to save themselves or customers money re-using the Inner Pinion Bearing and Race, and even sometimes the crush sleeve. I don't care if my car had 200-miles on it when getting a gear swap, a new Inner Pinion bearing is getting installed, regardless of the tools or confidence of the shop and/or mechanic. These few new additional parts cost only $75.00 at the most, and could be the difference between a happy or unhappy customer. FYI - I have no knowledge of TrueStreet, their reputation, expertise on gear changes, or how they do anything. My comments are simply in reflection of my personal preference. I buy my own parts and watch the mechanic do the install, or it doesn't get done. |
redredemption we will see you soon to get this guy torn apart to see what is going on! |
| All times are GMT -4. The time now is 11:30 PM. |
