Loud banging under car when hard rain...
2013 5.0 6-speed Manual
All stock except for cat back 9,200 miles This morning was the 2nd really hard rain I have driven in where there was standing water on the road. I get this really loud banging noise after having to drive through a few of the water puddles. It is very hard to pin point because these cars are very loud inside when raining hard. It seems to do it when I accelerate and it almost feels like the car is not accelerating as it should when it happens. Also, when I pulled into my parking spot this morning (hard left with clutch pushed in) it did it. It only does this when it is raining hard enough for water to collect on the roadways. Therefore it is very hard to reproduce it. Anybody got any ideas? |
How weird. That's going to be difficult to guess without actually hearing it unfortunately.
Advance trac may be kicking in. Its hard to tell without actually hearing the noise. If its still raining on the way home turn advance trac off and see if you can reproduce it. Ive noticed it will make kinda of a clunking sound when it kicks in sometimes.
It has only happened twice now. Althought the first time it did it , it lasted for the last 2 miles home. I honestly thought my exhaust had dropped down and was dragging across the road. Got home looked under the car and everything was fine. Went in changed and took it for a test drive and couldn't make it do it. |
The first time it happened 3 things ran through my mind: 1)exhaust came loose and was dragging ( obviously it wasn't when I checked) 2)Extreme exhaust leak ( I checked all exhaust clamps when on lift and all were tight) 3) really really really bad clutch chatter ( doesn't make sense when turning left into parking spot when clutch is pushed in and on the brakes though). |
I tell you what, I'll ask some of the other techs in the shop and shop foreman if they've ever come across a customer complaint like this, and will check TSBs and SSMs on the car and will get back to you.
Traction control w/o a doubt.
Also why would traction control come on when coasting into a parking spot using no throttle at all? |
| All times are GMT -4. The time now is 11:30 PM. |
