GTCS/Boss 302 Fascia Swap
I want to get the front fascia from the Boss 302 with the integrated foglamps. Has anyone done this swap already? Wondering if the factory wiring is already wired for this and just a plug-in-play option or if you have to do any custom wiring from a regular 2012 GT.
There is actually a member here selling the Boss/GTCS front fascia, if I'm not mistaken.
But to answer your question, the new fog lights will have to be connected using the existing grill fog light harnesses, but I think they should be plug and play. I'm not entirely sure though. |
Bump.
Has anyone here actually performed the swap? -Alex |
Grant808 I think is his username on here. He had it done to his car, but removed it recently.
It is easily doable by yourself. I'll see if I can get him to stop by here. You may have luck with a PM as well.
Edit, I can't seem to find his username on here anymore, so it seems he is no longer on the forum... |
Yea it's easy I did it on my 11
Just to swap the valance maybe like an hour or two. I did the boss splitter which requires drilling 26 holes
Plug and play just connect the harness for them
Thanks for the info man!
Yes very easy plug and play. Swapping the fascia piece is easy too. I've go removing the front bumper down to an art. I can get that sucker off in like 5 mins.
| All times are GMT -4. The time now is 01:25 AM. |
