-   -   Factory Brembos vs. Standard Brakes (http://www.dfw50s.com/showthread.php?t=2004)
Dominic Toretto 06-18-2013 11:36 AM
I have the standard brakes on my car. What are the differences? Rotor size? Number of pistons? Larger calipers etc? Wanting to know if I can add them in the future and if they will fit along with the wheels I bought. I assume so since
46Tbird 06-18-2013 12:11 PM
Yes to all those - the Brembo GTs and Boss 302s have larger rotors, more pistons per caliper (4 instead of 2) and larger calipers/pads.
I would not assume, because fitment over the Brembo calipers can be tricky. There are a lot of wheel makers that offer wheels that fit fine for standard brakes but don't fit over Brembos.
Kevin (04sleeper here) did a nice writeup on his Brembo brake swap. He always details his installs so you'll get a good idea of what is needed and what to expect.
http://www.svtperformance.com/forums...-my-13-cs.html
DirtyD 06-18-2013 12:16 PM
13.8" rotors on front with 4 piston calipers
standard are 12.8" with 2 piston
Dominic Toretto 06-18-2013 12:38 PM
Interesting. When I was selecting wheels to by, none of the options took into account whether or not the car has the Brembo kit. Just read options for fitment as "GT/V6" or "GT500."
03MachMe 06-18-2013 02:34 PM
if they fit on a GT500 they will fit brembos. the 07-12 GT500 has the same brembos as the brembo GT/boss. 13 GT500 has 6piston brembos
Dominic Toretto 06-18-2013 03:06 PM
Are the Brembos just the front set or do the rear brakes get upgrades as well?
DirtyD 06-18-2013 03:10 PM
Front only
BLK2012GT 06-18-2013 03:32 PM
I want the '13 GT500 setup. Ok I'm going to buy it now!!!!!
Craizie 06-18-2013 05:10 PM
I know the clearance on the factory Brembo's is TIGHT. like 2mm tight.
Rebelracer568 06-18-2013 06:56 PM
I installed 2012 gt500 brembo set up on my car I have a base model 5.0. Cost me $700 plus 200 for stainless steel brake line kit from steeda. Installed in 30 minutes super easy. Stop great. I have the sve drift 18" wheels no clearance issues
Dominic Toretto 06-19-2013 08:21 AM
Must stop the 5.0 great since that brake kit is designed around a much heavier(especially front heavy) car.
