FRPP P Springs
I've got a set laying around my apt waiting to get put on when I get my rims and tires put on too. Is there anything else I need to do with just swapping the springs?
A panhard bar may be required to center the axle.
If its in the budget new shocks and struts would improve the ride and handling as well.
My buddy at work told me that I should get a panhard bar.
I've heard that the P springs aren't an aggressive enough drop to change the suspension geometery enough to recenter the rearend.
HOWEVER, I would definitely recommend it. |
I will invest in one. Better safe than sorry. Would hate to go through all that and then have the car leaning like it just had some purple drank.
Caster/camber plates are truly the way to go to fix camber issues, but if your car will mainly see street driving, camber bolts will be plenty fine. |
FRPP P Springs
Thanks for the info :)
My car is lowered with BMR springs and I didn't need the camber bolts either. I have them sitting in a box in my garage. It's pretty easy to see how far off center the rear end is once it's lowered. If you wait about a week, there's bound to be 4th of July sales on parts. I'd suggest BMR, everything BMR on my car has been great and easy to install.
