-   1A Auto (http://www.dfw50s.com/forumdisplay.php?f=42)
-   -   2005-2008 Ford Mustang Ignition Coil (Set of 8) for V8 4.6L (http://www.dfw50s.com/showthread.php?t=2086)
1ATony 06-27-2013 11:44 AM
VISIT US HERE FOR GREAT PRICING 2005-2008 Ford Mustang Ignition Coil (Set of 8) for V8 4.6L
FREE SHIPPING IN THE LOWER 48 STATES!!!
http://static.1aautoimages.com/parti...00009/main.JPG
The ignition coil is a crucial part of your ignition system. It's function is to convert the 12 volt power of your vehicle's electrical system in to 35,000 or more volts. This produces a high intensity spark at the spark plug which then ignites the fuel in the cylinder. Coils in general will wear out over time. This will cause a misfire condition. In engines like this with one coil per cylinder you can diagnose a coil by putting a timing light on each one to make sure it is lighting the light consistently.
This coil over plug Ignition Coil SET features the following specifications:
Comes as a SET of 8
Brand New
Replaces dealer part numbers: 3L3E-12A366-CA, 3L3E12A366CA, 3L3U-12A366-BB, 3L3U12A366BB, 3L3Z-12029-BA, 3L3Z12029BA, DG 511, DG511
Built to strict quality control standard
Direct replacements
100% factory tested
This coil is a distributorless application. Sold as a SET of 8.
These are electrical parts and are all tested before they leave our manufacturer. This electrical item is not returnable; it is only eligible for exchange.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
