When do I need Swaybar Relocation?
I'm really looking to make a purchase of new wheels. I have my sights set on Avant Garde M550s. I'm trying to do a square setup but one site I found them on only basically allowed for a 10.5 rim out back with a 285 tire. If I have to end up doing this at what wheel / tire size will I need sway bar relocation?
BTW anybody know a good place that sells Avant Garde?
Jayman has them
Sway bar relocation brackets are only needed for 15x10 rear wheels (drag setup).
Danny, buy them from Jayman. Dona 20x9/10.5 setup with a 255-275/40 front and minimum 295/35 rear.
I have sway bar relocation kit brand new never installed if you want em.
I've heard you don't need them unless you are running wider than 315s out back. Given if your wheels are the correct offset you won't need them than either.
| All times are GMT -4. The time now is 03:28 AM. |
