-   -   Bone Stock Dyno Charts (http://www.dfw50s.com/showthread.php?t=2098)
Dominic Toretto 06-28-2013 11:05 AM
Anyone have any bone stock dyno charts? Wanting to see what I should be at. Only mod I have is an axle back which I don't believe would do anything really. I have an auto as well.
DirtyD 06-28-2013 11:13 AM
There are some around here somewhere.
Oxford14Stang 06-28-2013 11:15 AM
My 2014 5.0 6 speed dynoed out 358hp, 338tq(std) with just axle back and 3.55 gears which shouldnt affect anything. Was very disappointed in my numbers but the humidity was 70% which everyone including the guy who dynoed the car(at GearHeads) said is what killed my numbers. But as what was mentioned to me by some older vets in here. HP doesn't matter. Its how fast you can get what you have down the track. :) let me know what you dyno
DirtyD 06-28-2013 11:16 AM
Here is Don's car.
http://www.dfw50s.com/showthread.php?p=6675#post6675
DirtyD 06-28-2013 11:17 AM
My M6 car with 3.55s, Brembo wheels and tires (255/40/19) with GT500 mufflers only out down 378/365 SAE last Sept.
Zeek 06-28-2013 11:46 AM
I was same as DirtyD +/-2hp/tq manual 3.55s roush A/B stock base wheels n tires
46Tbird 06-28-2013 12:08 PM
2012 GT, M6, 3.73s, 20" cast wheels and drag radials
390/371 STD
If you use the correction factor to SAE (cf=.95456) then that works out to 372/354.
http://i13.photobucket.com/albums/a2...T/SANY0056.jpg
Dominic Toretto 06-28-2013 12:25 PM
Do you guys recall what dyno machines you are using? I heard Mustang dynos usually give a little more, ironically.
Rebelracer568 06-28-2013 12:44 PM
Gear heads uses a dyno jet. I know speedtek use dyno jets also
Courtesy Flush 06-28-2013 12:48 PM
Mustang dyno is usally a heartbreaker.
DirtyD 06-28-2013 01:11 PM
Pretty sure TS uses Dynojet as well
PLASMAN 06-28-2013 01:58 PM
Originally Posted by DirtyD (Post 37132)
I'll look when I get home I think I was 359/348 bone stock auto- since Steeda CAI, Jeggs ct deletes, GT500AB and new VMP tune 394/388 dynojet
rriddle3 06-28-2013 02:07 PM
Stock 2012 GT auto should put down 350-360 rwhp.
True Street uses a DynoJet.
Blackout 06-28-2013 02:30 PM
Dynoed at 376 on 89oct with really really bad weather...28% humidity that day
Dominic Toretto 06-28-2013 02:36 PM
Why are you dynoing with 89 octane? Why not go with 93? That's what I use only.
Is everyone using 89 octane?
