Differences in 11-12 and 13+ 5.0s
I have tried searching and can't seem to again find the actual differences in those motors. I searched before through google and found some link (can't confirm if it was Ford or not) that stated that there were some serious changes which allowed the update in power. Anyone have that info or a good link here?
There is no difference in power. The only difference is no oil squirters in the 13+.
A slightly revised tune on the 2013 gave them a smoother low end TQ curve, and also they "gained" 8 crank HP, but no one is sure where that was accomplished at (squirters or tune revision)
The 13+'s do also have the smaller head bolts which doesn't really effect power. There have been a few reports here and there about a head lifting under big boost applications but those are few and far between. |
the 13s are faster!
I figured I would read around for crate engines. Wouldn't the engines have a different part number if something was changed? From the fordracingparts.com website part M-6007-M50 looks to be what comes stock in the cars. However when you go to this page http://www.fordracingparts.com/crateengine/Main.asp#mod, it says the horsepower rating is 412 but when you click on the link it says the horsepower is 420. Weird.
My original thought when I saw the hp difference was either an intake or exhaust change. It seems like that would be the case since there are no different part numbers for the 412hp and 420hp motors. Thoughts? -Alex |
There are different part numbers for '11-12 and '13-14 service replacement engines from Ford.
In Sept of 2012, my '12 GT needed an engine replacement at 23700 miles. The engine they put in it is a '13 service replacement (BR3Z6006J) and required a slightly revised wiring harness and they reflashed the PCM. Picked up about 2mph in both the eighth and quarter... |
| All times are GMT -4. The time now is 11:30 PM. |
