Eibach Sportline and OEM wheels
What's going on guys, quick question. I didn't think about it till a few seconds ago. I'm planning on ordering the sport lines and was wondering if I'll have any clearance issues on the stock 235/55/18s?
no.
Okay, sweet. Thanks!
Get an adjustable PH bar.
Will do. Will buy it all and install it all together. Thanks for the info guys
You can stuff quit a bit more tire under there before having to worry about clearance issues.
Do yourself a favor and get new struts and shocks with your springs. If you're gonna go that far into the car, the factory struts are already coming completely off, and the rear shocks are only two nuts from coming off. The stock Ford Mustang GT shocks and struts suck donkey balls, and with stiffer springs, you will notice the shortcomings even more. Virtually replacing them with anything is better than stock, though I prefer the Koni Sports (yellow) for adjustment preferences. You can go cheap or expensive with some KYB's or Koni STR.T's (orange), Eibach, Tokico HP or D-Spec, Koni Sports, QA1, or Bilstein. |
Prolly the yellows on the softest setting
Koni Str.t are currently 330 shipped but you'll need GT500 strut mounts M-18183-C which are 100 shipped. We also have the sportlines in stock. This setup along with a PHB will set you straight.
Okay guys thanks for all the info. As for alignment goes our front end tech. At my dealership will be doing the alignment and the suspension work for me. That way it gets done while I'm at work and I can still make money :)
| All times are GMT -4. The time now is 11:30 PM. |
