Aftermarket Heads
I know the stock heads flow pretty well, but are there any good aftermarket heads that flow better or anywhere that can port the stock heads?
From what ive read its a tough mision to improve the stock heads.
The stock Coyote head flows more on the intake than Yates Ford Nascar head. Not a fair comparison exactly, since you're comparing two intake ports and valves to one, but it just shows you that they move a lot of air.
No one makes aftermarket heads for these engines yet. A few places will port them but there is a lot more room for making a mistake than there is for improvement. Jeff's heads have a Stage III porting job but I don't know who did them for TSM. |
So basically Port the Exhaust side and leave the Intke alone?
No, leave them completely alone and find other ways to build power. Unless you're trying to set n/a Coyote records...
So you are right, only up to ~.500" lift, but that is still pretty damned respectable. http://www.mustang50magazine.com/tec...e/viewall.html |
The heads on the new coyote engines are pretty badass out of the box but as with everything, they can be improved. Although not very cost effective when compared to nitrous or boost, when you are dealing with only 302 ci, the power number gain may not be much, but look at it on a % gain. When you can do basic hci on a coyote and make damn near 500 rwhp with a stock bottom end, that computes roughly 1.6 hp/ci thats fucking huge!!! Technology has improved so much in the past few years its crazy! I am in the process of putting together an engine package for a dirt track car. Plans are to run 302 ci old school sbf and get around 400 fwhp using stock bottom end, stock iron heads with 0 port work allowed and only using a 380 cfm carb.... talk about a challenge.. haha |
So basically at this point the cost doesn't outweigh the performance gain?
You will pick up 20-30 hp with ported heads
If there is ever an aftermarket head designed for this motor, if will likely be a few years off, but for now, Ford Racing will gladly sell you some fully CNC ported Boss 302S/R versions for $2700. Unfortunately, you can perform an entire list of upgrayedd's that will pick up as much or more power than the heads alone without going into the engine itself, but if you have ambitions to build a motor without a power adder, then the Ford Racing M-6049-M50BR and M-6050-M50BR heads might be on that list. |
| All times are GMT -4. The time now is 01:25 AM. |
