-   -   Control Arms (http://www.dfw50s.com/showthread.php?t=2168)
Dominic Toretto 07-08-2013 08:38 AM
Control Arms
At what point should one consider switching to aftermarket control arms? I see a lot of aftermarket manufacturers producing upper and lower rear control arms for these cars. Since I am stock-piling parts right now, wasn't sure if this was something I should go ahead and get as well. Thanks guys.
BlueBolt 07-08-2013 09:11 AM
If you have any wheel hop or are lowered any then yes get some control arms
5PointSlow 07-08-2013 09:41 AM
I run the brembo/GT500 stock lowers with roush upper. No wheel hop issues and no NVH.
JDBishopArts 07-08-2013 11:06 AM
BMR makes a good product and Jason (Jayman) with Hypermotive Performance, one of our vendors has great deals and service on them.
Dominic Toretto 07-08-2013 11:33 AM
What is NVH?
DirtyD 07-08-2013 12:10 PM
Originally Posted by Dominic Toretto (Post 39104)
What is NVH?
Noise Vibration and Harshness
Dominic Toretto 07-24-2013 09:04 AM
Anyone considered using GT500 control arms? I would assume that they would be much stronger than the stock GT control arms and probably still able to argue them for warranty issues.
jayman33 07-24-2013 09:30 AM
Dealerships would be hard pressed to void a warranty or determine the cause of an issue was due to using aftermarket LCA's.
Also, the GT500 LCA's are still stamped steel with rubber bushings. Deflection isn't necessarily bad in a suspension but too much is.
I spent the majority of my day yesterday grilling a race team on their suspension and they proved my theory right in regards to LCA's. BMR or Whiteline are the brands I would choose. I have Whiteline's LCA's on our 650HP GT, my Boss and our 800HP GT500 with zero issues and zero increased NVH. Both brands use a soft enough material to offer a little deflection but are hard enough to eliminate those typical issues found in street driving.
Dominic Toretto 07-24-2013 09:47 AM
Thank you for the informational and prompt response :). Since the GT500s (Assuming regular GTs the manufacturing process) are stamped steel, what are the Whiteline and BMRs manufacturing process for these pieces?
DirtyD 07-24-2013 10:49 AM
Tubular steel with penetration welds at each joint. I don't know if they are full penetration or not, though.
Sent from my iPhone using Tapatalk 2
jayman33 07-24-2013 03:12 PM
Correct, whiteline use 4130 chromoly with tig weld. BMR is mild steel with I beleive mig weld.
emery2483 07-24-2013 08:52 PM
what do y'all think about the bbk lca?
jayman33 07-24-2013 10:26 PM
Dont know much about them
Toby 07-24-2013 10:48 PM
You can't go wrong with bmr stuff. I have installed dozens of them with great fitment every time! also dont forget about the relocation brackets if you are lowered and plan to hit the track.
Give us a call at Truestreet, we are a dealer for BMR stuff, we can get you a great price on the parts with installation!
Luke 07-25-2013 10:03 AM
+1 for BMR!
