-   -   Check engine light (http://www.dfw50s.com/showthread.php?t=2322)
Pat McCrotch 07-27-2013 04:06 PM
Check engine light
Mine came on yesterday. Plugged the SCT in and code says Random misfire detected. anyone had this yet?
31,000 miles on the car, Is it time for a tune up? new plugs etc? I do not know a lot about engines, but can change plugs if thats all i need to do.
What else could it be? any input will be appreciated.
Thanks
JDMLOL 07-27-2013 04:12 PM
Thanks
Could be a lot of different issues. The cheapest would be to swap coils on the misfiring cylinder and see if the misfire moves. If it does move, replace it. I typically replace all of the coils and plugs for good measure. If you can and it's still under warranty, put it to stock and take it in.
Pat McCrotch 07-27-2013 04:34 PM
with headers and catted X, cant really put it back to stock. and not sure what one is misfiring, it just said random misfire detected. Guess i will change all of them and go from there. Thanks
JDMLOL 07-27-2013 04:43 PM
I meant the tune. Idk how they'd feel about exhaust but some dealers are more lenient than others.
Yagermeister 07-27-2013 06:34 PM
Have you recently changed your clutch?
Pat McCrotch 07-27-2013 07:49 PM
Sometimes, I wish the car had a Clutch...
Yagermeister 07-27-2013 08:12 PM
Have you changed the converter recently?
re-rx7 07-27-2013 08:19 PM
Weird. I went to downshift mine today from 3rd to 2nd and my car hiccuped and flashed the check engine light just for a sec. Back to normal after that.
Pat McCrotch 07-27-2013 08:31 PM
Nope... Happened 1st a few days ago, I changed the tune that I have been running for over a year "93S" to the 93R. I had been so happy with the 93S I forgot about the 93R, so I tried it, code came in after 10 min of driving. Put the 93S back on, code went away, then 2 days later came back yesterday.
Last night, I loaded a different tune from different company, drove to and from work today with no issues yet, but is still idling a little rough.
Yagermeister 07-27-2013 08:55 PM
Clear the KAM and do an idle relearn and you'll probably be good
Pat McCrotch 07-28-2013 08:15 PM
I will try that when I get back in town.. One thing I did notice before I left, It looked like one of the hoses going to the Moroso air/oil separator was collapsed in one spot.
I am definitely going to get better hose to change that out, but could this be what caused the random misfire code?
Yagermeister 07-28-2013 08:44 PM
Not sure about that but IF you had changed your clutch or converter you should do a misfire profile correction procedure at the dealer.
Yagermeister 07-29-2013 09:15 PM
Loose crank position sensor maybe?
ochoblanco 07-29-2013 11:04 PM
This...common issue on the coyotes. You could also pull a plug to see if its fouled. I know mine were fouled out bad from the Trackey programming running lean up top.
46Tbird 07-30-2013 09:20 AM
Mine got a steady Check Engine Light two days after the engine was replaced. It came back with random misfire codes for various cylinders. The dealer tech had to do a 'crankshaft position relearn' process and that cured it.
PS - I don't like your 'idling rough' comment because that was the first symptom of my piston letting go. After about five miles of rough idling, the CEL came on steady, then the next morning it began flashing. The piston on cylinder 8 had cracked the top ring land. Hope yours is something else.
