Boss Rear diffuser
Anybody have it? How was the install?
Midnight and 03MachMe have it. I don't think the install is too bad.
I hear conflicting stories as Ive searched Google. Some say easy some say hard. I think looks so much better.
There is a install guide on SVTP for the Boss diffuser.
Ask Nic. I know he mentioned several times it involved drilling 26 holes. Lol.
I believe its a bolt on for the 11-12 the 13-14 require cutting.
its easy had/have both...
Im assumng it mostly for looks because i cant see it working.
It does help the air flow a little better under the rear of the car, but it's not going to really be noticed at all. Just gets rid of the "flat" wall causing turbulence as the air flow exits under the car.
http://i44.photobucket.com/albums/f3...ps022588cf.png |
Its is just for looks. Your not going to see any improvement on a street car. And it's not stable enough if you get to the speeds it would make a difference. The install for a 13-14 is simple. The bumper has a line that tells you where to cut. Takes a couple hours at most
Wasn't bad at all I used this http://www.svtperformance.com/forums...tal-guide.html
