5w50-ouch
Picked the oil for first oil change. Track pack = 5w50 =$10/qt.
Yikes!!! |
10 bucks a quart is nothing... lol
Don't know what brand or where you bought, but if you did it yourself, you could have spent 10-minutes searching Walmart, and other local part stores and found a better price. |
wtf??? This is going to sound dumb, are you sure?
It's what the owner's manual specifies for the 2014 GT w/Track Pack.
Did not find it on the shelf anywhere else. Can find Motorcraft online, but very close to the same price, so I picked it up at the local ford dealer. Not many choices for full syn 5w50, even less that meet the spec. Castrol makes one that is the cheapest, but doesn't meet the spec. Redline makes one and meets the spec, but is even more expensive. Mobil one cost is similar but doesn't meet the spec. Royal purple doesn't show as making it. Maybe amsoil, but that ain't going to be cheap either. Not many cars spec 5w50. E.g. GT500, BOSS, track pack, and Lexus LFA. |
The 5w50 is great... for a racecar, not a daily. That weight is only used in cars that are thrashed on a daily basis. Its a race oil plain in simple. It might sound cool, but without a built motor, or excessively high cylinder head temp its really pointless. Might at well put some good old Rotella T 15w40 in there.
I have a 13 Track Pack that calls for 5w50... I just run RP 5w30 HPS or XPR, then again im heavily modded, don't want to use those if you are keeping warranty.
You made me second guess what the dealer put in when i was last there... sure enough 5w20. Should have looked more closely at the damn service ticket before i left.
I don't care if it is only for "track use", i want what the damn engine calls for put in, specially when i paid for a maintenance plan. |
I'm running Amsoild 10w30 love it. 7k miles on the oil so far. I will be doing an analysis at 10k
As an engineer myself, I'd be fairly certain a cost conscious company like Ford wouldn't call out such a high spec oil unless they truly saw the need. If it is only truly required for certain scenarios then so be it. So we know that the ECU will dial back the engine if oil temp gets too high. What I don't know is if they move set point up in the track pack calibration to take advantage of the better heat resistance of the heavier full synthetic. I have been told that the regular GT (non BOSS) guys tend to run into heat limits at the track. Paid good coin and special ordered to get the track pack, won't cheap out now. |
| All times are GMT -4. The time now is 11:33 PM. |
