-   -   help!!!! (http://www.dfw50s.com/showthread.php?t=2489)
Smurf50 08-20-2013 01:53 PM
help!!!!
I was installing the tune sent to me from Bama and it said failed, now the damn car won't start! I'm stuck at the exhaust shop and no clue how to fix this!
Smurf50 08-20-2013 01:55 PM
I also tried the suggestion from the sct to return to stock, and it failed that too...
Midnight11 08-20-2013 01:56 PM
Unplug the neg from the battery as wait 15-20 mins then start again
DirtyD 08-20-2013 01:58 PM
Turn on your headlights, actual ON mode NOT Auto mode.
Disconnect the negative lead from the battery.
Wait 20-30 min for the system to completely drain the charge and cool down the ECU.
Turn off headlights.
reconnect battery lead
Return car to stock ensuring you keep all doors closed, radio off, a/c off, etc.
Then reupload the tune.
Phuck Phace 08-20-2013 01:58 PM
This happens weekly, I swear.
Smurf50 08-20-2013 02:19 PM
If I can get it back to stock I am going to get the work done and get it home. I'll update the tuner then try a flash again...
Nay 08-20-2013 05:29 PM
I just updated my sct tuner last Thursday seemed like a big update, took about 20 mins just for the update.
JDBishopArts 08-20-2013 05:51 PM
If you have jumper cables or a jumper pack hook it up first. What is happening is that you aren't getting a constant high enough voltage from the battery to the ECM when it is uploading. Usually due to your radio/AC/doors open etc.
Return to stock. Then reload the tune. Turn everything off. Keep the doors closed. If you have jumper cables or a jump pack it wont be a problem.
JDBishopArts 08-20-2013 05:54 PM
You don't need to update your SCT. That's not the problem.
JDC 08-20-2013 06:49 PM
This recently happened to me. Make sure everything off. (The AC, radio, lights, ect.) also Pull the fuel pump fuse and fan fuse.
Then flash to stock and then your custom tune.
Worked for me. Good luck.
Smurf50 08-20-2013 08:30 PM
It's back to stock, and I am updating the tuner just to be sure.
I will try to reload the custom tune here after it updates...
Good news is that I got the work done, so for now I am done with mods :D
DirtyD 08-20-2013 08:35 PM
Does the fuel pump not prime while these cars tune? I know my F150 would constantly prime the pump while it was tuning. You could hear the whine.
Smurf50 08-20-2013 08:43 PM
I am pretty sure I heard it while it was going back to stock earlier :)
DirtyD 08-20-2013 08:48 PM
I'm pretty sure it does. Just make sure all accessories are turned off when you do it.
Smurf50 08-20-2013 08:53 PM
Yea, I am pretty sure it was just a one-off error, and shouldn't happen again. I was told by the guys from BAMA that if the device is not updated, sometimes this can happen...so I am making sure it's updated :)
