-   -   Mustang front lower control arm install (05-10) (http://www.dfw50s.com/showthread.php?t=2513)
Tony@Latemodel 08-23-2013 12:16 PM
FRONT LOWER CONTROL ARM INSTALL
Get rid of all those pops, squeaks and other annoying sounds coming from your front suspension! These are typically caused by worn out front suspension components. One of the major components that wear out are the front lower control arms. The control arm bushings and ball joints wear out over time and cause noise or uneven tire wear. This was the case with our S197 Mustang.
Lucky for us, Ford Racing has preassembled GT500 front lower control arms for 05-10 Mustangs (Part #: M3075E). These control arms have new and improved bushings and ball joints already installed on the control arm. This eliminates the need to remove your old ones from your factory control arms. Installation can be done in your driveway with simple hand tools, a jack and jack stand. Follow along in the how to video as Jmac walks you through the installation process.
