-   -   Exhaust Rattle (http://www.dfw50s.com/showthread.php?t=2613)
Sieran 09-03-2013 08:46 PM
Exhaust Rattle
Not sure what to make of this... going to try and get it into an exhaust shop this weekend to see if they can fix it. If not, X/H pipe replacement? Doubt the dealer would warranty it since i removed the resonators.
Maybe slag from them welding in the pipe where the resonators used to be? Would think that would get blown out though when i push the car some?
I think this is what i am hearing when i drive... thought it was my LCAs, but after hearing this i don't know.
DirtyD 09-03-2013 10:43 PM
Sounds like flange or clamp bolts are loose rattling around.
Sieran 09-03-2013 10:54 PM
I thought so too, but i couldn't find anything to tighten down... Everything was as tight as i could make it unless i brought out my torque wrench which gives me more leverage.
It makes a creaking noise too when i lift up on the exhaust... almost like a broken weld joint. Just going to bring it back to the shop off 75 between park/parker that took my resonators out and have them put it up on a lift.
