If you are like me and many others here that use the SCT X3/SF3 handheld tuner for uploading a tune to your car, then you have probably have a failed upload one or twice, or even more than that.
FIRST AND FOREMOST, save your stock tune file from your X3/SF3 on to your computer, flash drive, or other media type so you can always have it in case your handheld loses it or you update the firmware without returning to stock. I am posting this thread in hopes it will become a sticky for anyone in the future that does not know how to resolve this issue, so they don't have to take the time for someone to respond to their post about it while stranded somewhere. The information and suggestions shown here ONLY correlate to 2011-2014 Mustangs. Cause: The Ford Copperhead ECU requires a certain voltage to be maintained at all times during the flashing process. Sometimes even a small variance can cause the ECU to go into failsafe mode and close all access to the ECU if there is not enough supporting voltage. Between the handheld communicating with the ECU, and the ECU trying to handle other duties while tuning, this can turn into a rather frustrating and common occurance. Open doors, radios, other accessories may cause this issue as well, or add to it. Effect: When the voltage drops below what the ECU needs, all access ports and communication from the ECU stops. So your handheld that was currently uploading your custom tune or stock tune now has given you the message "Download Failed". Solution: The one option that I've found to work best for fixing the failed upload to allow you to return the car to stock si listed below, as a procedure.
There are a few different routes and suggestions you can use to prevent this from happening in the future.
Hopefully this will help anyone else in future need of this answer to a recurring problem. |
Stuck :)
Thanks, Steve. |
if you loose your stock tune file, how do you go about getting that back?
Great write up. Your suggestions have helped me.
Only thing I have to add, is that you do not have to wait 20 minutes to try to reload the tune. Waiting 20 minutes doesn't guarantee that reloading the tune will work if you have everything turned off.
Quickest solution is to plug the battery into a trickle charger/jumper pack/or jump cables hooked to another car. You can reload the tune immediately. You don't have to wait the "20 min". You don't have to call a tow truck. You just need power. Resetting the KAM usually takes a couple of seconds if you do it right. You do have to disconnect the battery. Pumping the brakes and turning on and off the lights helps. The power the PCM stores goes to the lights. After you pump the brakes a few times you can reconnect the power. Hook it up to a power source and reload the tune. It will work every time. Main thing is, if you want to load a tune to your car, if you don't hook it up to a power source there is a good possibility you can brick it. I use my jumper pack. Every time I've had it hooked up it's loaded with no problems. |
I listed the 20 mins just as a safe bet that the system would be completely drained. |
| All times are GMT -4. The time now is 07:14 PM. |
