Mt82 wine 1st-3rd
After running a couple passes at Ennis I now have a transmission wine. I can live it with, no big deal but kinda sad about it.
How many people have this problem? |
Will they just whine for awhile or are they going to give out shortly after it starts? I can deal with a whine, hell i'm used to having a 3550 in my old cars.
And i'm guessing the better option, far as 6speeds go, is just putting a T56 in the car? |
I've never noticed a whine in mine, even after 5 passes at TMP.
Mine has a whine. 4th will start soon. Mine is getting fixed soon. Most likely input shaft bearing if not new tranny time!!
Mine has a slight whine too. Nothing terribly noticeable. I would say if it gets progressively louder and/or you notice any difference with being able to get it into gear get it looked at. Most people have the whine problem and so far I haven't seen it lead to much other than some extra noise.
Is this not something that can be fixed under the warranty for you manual guys? I drove a manual car before that didn't have a whine so clearly if it came from the manufacturer without one, I would definitely get it serviced.
:shrug:have had numerous passes down TMP and a lot of autox runs and 0 whine from mine
If it bothers you enough get it checked out. I truly think the mt-82 is prone to it.
Mine whines bu the tone hasnt changed since it started.
Ya I could always hear a very very slight whine since i've had the car. Nothing compared to the noise the tranny made on the 01 stang I had and never once had to do anything to the tranny other than a new clutch from being worn down over time.
Mine started the whine after the first pass down MIR 2 years ago. Did nothing about it but drive it, and race it, as much as possible. Now, 2 years and 38000 miles later, the whine has almost completely gone away. You can still hear it for a few seconds, pulling away from a stop sign in first gear, as long as the windows are down and you are next to a curb or something similar that will reflect the sound back at you. Other than that, it has healed itself over time.
| All times are GMT -4. The time now is 01:02 AM. |
