Brand New Goodman ac/heat unit
Brand New still in Box $775
Goodman CHPF3636B6 3 Ton, W 21 1/8 x H 17 1/2 x D 26, Horizontal Cased Evaporator Coil Goodman GMS80453AN Gas Furnace 45k 80% Up/Horiz Description: •TuffTube™ tubular heat exchanger •Lifetime heat exchanger limited warranty •Norton® mini-ignitor •Single-speed induced draft blower •Four-speed direct-drive circulator blower motor •Integrated electronic furnace control board with self-diagnostics •Low voltage terminal block •No blower insulation •No electronic air cleaner or humidifier terminal •Bottom pan purchased separately •Single-stage combination redundant gas valve •Foil-faced insulation lines heat exchanger compartment •CFM rating at high speed AFUE: 80.0%; BtuH Input: 45,000; BtuH Output: 36,000; CFM @ 0.5" ESP: 1,298; Depth: 28"; Height: 33-3/8"; Mfg. #: GMS80453AN; Min. Circuit Amps: 8.1; Nom. Tons: 3; Vent Size: 4"; Width: 14"; Wt. Lbs.: 120 |
| All times are GMT -4. The time now is 11:30 PM. |
