-   -   Best Way to Remove Fake Fuel Door (http://www.dfw50s.com/showthread.php?t=3014)
Dominic Toretto 11-01-2013 09:28 AM
Looking for suggestions. if you all have any easier methods than using a wedge and heat gun. On my previous car, to remove the side moldings, which were attached to the car by double sided tape, I just soaked the glue with Goo Gone and used fishing line to "saw" it off. Of course that car was made out of plastic so not sure it will be safe for this car.
DirtyD 11-01-2013 09:55 AM
Are you talking about the faux gas cap? There is actually a hump in the trunk that it fits over. It's has pins/pegs that insert into the hump, and those typically brake. If you want to completely smooth it down, you have to break out the Dremel and a metal cutting wheel.
Dominic Toretto 11-01-2013 10:07 AM
Yes, the faux gas cap, I don't plan to reuse it. I bought the CDC rear decklid panel.
DirtyD 11-01-2013 10:08 AM
Yeah, you need to cut the cap off.
Get with JDBishoparts. He cut his off and may be able to give you some pointers.
JDBishopArts 11-01-2013 10:34 AM
If you bought the blackout panel then you have some serious modifications to do. That's one of the reasons I bought the one I did. You don't have to cut it off.
The plastic part you don't have to do anything with. It's all one piece. You have to take two screws out and pop the panel off. I'd take the interior liner out too. If you were like me and knew you weren't going to use it again I was a little rough and ended up breaking off a couple of the tabs and had to fish them out of the trunk.
If you have the one were you have to cut the metal part off the back Id recommend a dremel and a hole saw. Then make sure you prep the exposed metal and paint it or you'll get rust...and quickly.
Dominic Toretto 11-01-2013 11:11 AM
http://www.americanmuscle.com/cdc-rear-panel-2010.html
That's the panel I bought.
Here's the instructions on the site.
http://www.americanmuscle.com/cdc-de...0-install.html
I don't see anything that looks to require any cutting or sawing. Perhaps it's different on the 13+ cars?
re-rx7 11-02-2013 10:58 AM
Its a PIA from what Ive heard.
JDBishopArts 11-02-2013 12:42 PM
Yes it's different than the black out panel that I was talking about and it's different than the 12's. It's all connected on the plastic panel. You just have to pop it off. 100x easier than the 12s.
fordplay 11-04-2013 08:45 AM
Ummm if its what I'm thinking .. I pulled the one off my 11 in like 10 minutes on a 100 degree day. Its double sided tape and 2 push pins . Zero tools but maybe use dental floss? After seeing how they are held on.. I'm surprised they don't just fall off more
Dominic Toretto 11-04-2013 11:02 AM
Yeah same thing, I have a 12. It's a bit cooler outside now, so I haven't done it because the instructions say to install the panel at a temp warmer than 70*. I'm assuming the panel will not adhere as it is supposed to in cool weather.
fordplay 11-05-2013 08:52 AM
There are holes in the metal where two pins go in and are held in place by 2 plastic gripper friction nuts.. that's what mostly holds them on, the tape.. ehhh.. that being said.. it is plastic and does flex a lot on install and removal, waiting till its warm is most likely the better idea
