-   Hypermotive Performance (http://www.dfw50s.com/forumdisplay.php?f=37)
-   -   Team Hyper's custom Roush TVS kit "The best special" (http://www.dfw50s.com/showthread.php?t=3022)
jayman33 11-02-2013 05:17 PM
Are you looking for the special custom TVS package but you're unsure what parts best go well together? Well we at Hypermotive are taking the guess work out of your decision, teaming up with injector dynamics, VMP tuning and Roush we are offering the "best" package available for you 5.0 Coyote. Our custom Hypermotive Roush TVS kit will without a doubt leave you smiling ear to ear.
Here is what you'll find in our custom kit, enjoy!!
Mustang Supercharger Tuner Kit , R2300 2011-2014 featuring new TVS Technology. The new Twin Vortices Series features new four-lobe rotors and high-flow inlet and outlet ports that greatly enhance thermal efficiency, enabling greater volumetric capacity at higher revolutions per minute (RPM)
Custome Remote tune by famous and nation renowned tuner: Justin Starkey of VMP
Capable of producing over 850 horsepower
High flow fuel rail
Injector Dynamics ID725 or ID1000's
Pulley sizes:82mm/ 79mm/ 75mm/ 72mm/ 69mm (please advice that anything under 79mm pulley we recommend a build bottom end)
ROUSH Fuel Pump Voltage Regulator to moderate fuel flow and ensure a proper fuel-to-air charge ratio
Plug-n-Play wiring harness where no modifications are needed to the vehicles fuel pump wiring system
Fuel charging assembly with ROUSH designed upper and lower aluminum intake manifolds
High efficiency intercooler system featuring a large full face low temperature radiator, over size coolant degas bottle, high capacity air-to-water intercooler and formed hoses with abrasion-resistant sleeves
Twin 60mm throttle body spacer
ROUSH cold air induction system with 110mm MAF tube, washable/re-usable open element air filter and air dam
Please contact Hypermotive directly for options concerning custom fuel systems, upgraded throttle bodies.
6999.99 shipped
http://www.shop.hypermotiveperforman...ecial-TH50.htm
