-   -   Flashing Check Engine Light (no codes) (http://www.dfw50s.com/showthread.php?t=3030)
RangerDLA 11-03-2013 07:49 PM
Hey guys,
I took the Boss for some spirited driving and during so, the check engine flashed for about 20-40 seconds and went away. All gauges were normal and nothing seemed out of sorts, but it was a concern. I returned home and ran the scanner, showing no codes. Just curious why it did that. My only engine mods are Parnelli Jones CAI and the AED tune. I was running the lopey idle tune. Any help would be great. Thanks
JDMLOL 11-03-2013 08:01 PM
Can your scanner check for pending codes?
RangerDLA 11-03-2013 08:37 PM
I'm not sure. It's an SCT Tuner. I have another scanner that I didn't use. I'll try it too.
JDMLOL 11-03-2013 08:41 PM
My torque app for my phone will show historical and pending codes. Pending meaning that it could turn into a fault code that will trip a solid CEL within x number of drive cycles or if the problem goes away within x number of drive cycles it will clear out. I forget how long pending codes are stored. I thought I read 40.
RangerDLA 11-03-2013 10:28 PM
After a little research, it looks like I made need a high rpm pulse ring. Can anyone shed some light on this and school me on the uses for this part? Also, how is the install?
JDMLOL 11-03-2013 10:56 PM
Based on some google searching it looks like a crank position sensor and a pulse ring are the same thing. I'm assuming your tune raises the rev limiter on the Boss north of 7700 rpms. According to what I saw, it is to allow the pcm of high rpm engines to accurately monitor timing. Looks like it goes on or near the flywheel/flexplate.
RangerDLA 11-03-2013 11:21 PM
I would agree with you. I doubt I can install it myself though. LOL.
