Suspension Direction Change
So right now I have Koni STR.Ts and HR Race springs and BMR Panhard.
Thinking about changing it up to BMRs and strange struts/Viking shocks. Could I make what I have now work or just make the switch? |
What are your goals? What about your current setup is not "working"
x2?
I might just add LCA and Relos but not sure if The race springs and STR.Ts will work for cutting good 60's
Yeah, race springs are made for turns. But unless you're really looking to do some damage at the track I wouldn't worry about it. LCAs and brackets will help a lot. And tires.
If you're really wanting to cut some serious 60ft times the race springs are not ideal. |
I got some D-Specs i'd be willing to get rid of if you want to go adjustable :D
I've got my eye on strange and bmr combo
Ordered
BMR Springs Strange shocks/struts BMR LCA and Relos BMR UCA Mount |
Well after a couple hrs I got everything on but the UCA Mount, Seems BMR forgot to put the Bolt, Nut, and washer for it. So I took the stock one out for nothing just to break everything down and realize it was missing some parts.
| All times are GMT -4. The time now is 06:41 PM. |
