Manual Trans cable bracket
I can't find this part,
Ok you know how you have a small like 3 inch steel braided cable from the shift fork in bell housing that connects to a lever for the clutch pedal cable. I'm looking for the metal bracket that connects the little steel braided cable to the lever. Where can I find it? |
Sorry I just described the 4 cyl.
I need the bracket that holds the shift cable in the other side of the shift fork |
Have you looked on corral.net I have found lots of small parts like that.
