Questions about suspension mods..
Hey,
I'll be buying a ton of BMR suspension mods within the next week but am still really torn on a few things.. I want to be able to hook at the track and still use this as a daily driver and occasionally 2-3 times a year go to a autocross event and be able to do that as well.. What type of shocks/struts would you guys reccomend? I've been told that koni yellows would be a good all around shock/strut some people told me to just stick with strange adjustable struts and viking or QA1'S adjustables for the rear. I'd probably be going to the track atleast 2ce a month if that helps make it easier. Would like to eventually throw a twin turbo kit on the car as well within 2-3 years.. heres a parts breakdown of stuff I'm buying: 1) BMR Rear sway bar SB023 2) BMR adjustable front sway bar SB022 3) BMR panhard bar relocation bracket PHR008 4) BMR adjustable panhard bar PHR006 5) BMR uppper panhard bar support brace PHR007 6) BMR adjustable rear upper control arm assembly UCTA032 7) BMR rear upper control arm mount UCM002 8) BMR rear lower control arm relocation brackets CAB005 9) mamimum motorsports caster camber plates 10) BMR sway bar relocation kit SRK001 11) BMR lowering springs SP009 Still torn on what shocks/struts i wanna use 12)koni yellows (the best) or 13)Strange adjustable front struts and viking double adjustable rears |
I know a few guys use the konis for double duty and don't have any problems. I am going more for the auto X and road course with a little drag rarely mixed in so that is why I went with the konis. I have no idea how the strange and viking shocks would do on a autox or road course. The rest of it looks spot on tho. Also are you trying to break records or just going to have fun?
Well for now just fun.. Lol but ive always liked being at the top of the pack when performance is concerned. I sold my nissan titan 8 months ago and my N/A record of 12.92@103 still stands after 7 yrs as well as my boosted record of [email protected] this was in a 5300lb truck that had the aerodynamics of a house, lol
I should easily be able to beat these times in the stang with maybe 1-2 more mods.. Last time i went to the track i kept getting locked outta 4th. So i got the MGW shifter and BMR LCA's cause the traction sucked balls. Best 60' of the night was a 2.2 and most where 2.3 to 2.4 I aslo got the bama tune but havent been back to the track since i was bone stock.. |
You should be able to bring that 60ft down to at least a 2.0 with more seat time. I was able to cut a 1.8 on stockers when I was stock and after Intake/Mid/Tune. 8.3 stock and 8.0 tuned was the best I could manage but I was on warn out 20s.
I have the KONI yellows and love them. So far I have: BMR Adj panhard BMR LCA's BMR LCA relo brackets Eibach Adj front and rear sways H&R Race Springs I didn't get the swaybar relo because I don't ever plan on running 15x10s. AutoX is a blast. You'll love it. We are installing Ryan's KONIs, Brembos, both are changing brake fluid to MOTUL and I have Vorshlag C/C plates going on. You're welcome to come! Here's a vid. haha |
Heres a list of what ill be buying this friday :)
1) 2013-2014 Borla Stinger Stainless steel catback 2) BMR Rear sway bar SB023 3) BMR adjustable front sway bar SB022 4) BMR panhard bar relocation bracket PHR008 5) BMR adjustable panhard bar PHR006 6) BMR uppper panhard bar support brace PHR007 7) BMR adjustable rear upper control arm assembly UCTA032 8) BMR rear upper control arm mount UCM002 9) BMR rear lower control arm relocation brackets CAB005 10) mamimum motorsports or vorshlag caster camber plates 11) BMR sway bar relocation kit SRK001 12) BMR lowering springs SP009 Still torn on what shocks/struts i wanna use 13)koni yellows (the best) Or 14) strange struts with viking double adjustable shocks |
those are nice.. might have to paint the top plate black though.. lol
Don't worry about the color. The plate is almost entirely hidden inside the strut tower.
If you really want to compete in Autocross, first choose a class. That parts list you chose will put you into SCCA C-Prepared where you will be up against gutted tubs on racing slicks, not DOT-R Hoosiers. My recommendation would be to look at either E-Street Prepared, or Street Mod if you are going to be doing internal engine mods. As far as suspension goes, I'd use Motion Control TT2 dampers and our Vorshlag camber plates, Whiteline Watts, and depending on the class, either an upper arm (ESP) or lower arms and relocation brackets (SM). I'd add Whiteline front and rear adjustable bars and end links and then stick 18x11 wheels front and rear with 315/30-18 Hoosiers. |
| All times are GMT -4. The time now is 11:31 PM. |
