-   Want To Buy (http://www.dfw50s.com/forumdisplay.php?f=24)
-   -   WTB Stock Upper Strut and Shock Nuts ASAP (http://www.dfw50s.com/showthread.php?t=3118)
BV600 11-14-2013 10:37 AM
My konis came with the upper nut but the strange shocks didn't and I manages to sell my stockers with the nuts on them.
brembo12 11-16-2013 06:46 PM
you can have my brembo 55d fronts for 55 bucks...struts/mounts/nuts etc less than 10k miles........i have the rear shocks as well...75 for the entire shootin' match
DirtyD 11-17-2013 12:08 AM
There are no 55D front springs....
five.slow 11-17-2013 03:37 AM
Just go to the hardware store and get new hardware.
BV600 11-17-2013 12:02 PM
Yeah I went to hardware store
brembo12 11-19-2013 04:17 AM
good day..
Brembo Brake Package (Mfr Code 55D)
Front Sway Rear Sway Front Springs Rear Springs
Base GT
34.6 mm 24mm 123 lbs. 156 lbs.
Brembo (55D)
34.6 mm 24mm 131 lbs. 167 lbs.
Boss 302
34.6 mm 25mm 148 lbs. 186 lbs.
Laguna Seca 34.6 mm 26mm 137 lbs. 191 lbs.
Andy the webforum owner over at brembo50 also calls his 3/4 real drop springs 55D Package springs......i also have a set of them for sale......
Front: 14" Brembo® vented rotors with Brembo® 4-piston calipers
Rear: 11.8" vented rotors
Unique electronic stability Control® (ESC) tuning
19" X 9.0 dark stainless painted aluminum wheels with 255/40R19 summer-only tires
Tire mobility kit replaces spare tire
Aggressive suspension tuning
brembo12 11-19-2013 04:29 AM
http://autos.msn.com/research/autopr...ear=2014&UTN=0
