-   -   Automotive Machine Shop to grind/turn rotors? (http://www.dfw50s.com/showthread.php?t=3171)
Torsion 11-20-2013 11:57 PM
I have a rotor that seems warped or has a weird transfer layer on it.
I'd like someone to make it straight.
Anyone have a recommendation for a shop that does a good job on rotors? I've been warned not to just take it to autozone for a turn...
03MachMe 11-21-2013 12:05 AM
If it is warped you might just be better off buying new ones. Stock rotors or aftermarket
Torsion 11-21-2013 12:22 AM
Understood... but I'd like to know if machining the rotors is an option.
merlinmol 11-21-2013 01:47 AM
Several auto parts stores used to be able to machine rotors. There is no reason you can't have the stock ones done.
fordplay 11-21-2013 08:32 AM
I'd just go to the brake performance Web site and get some cross drilled rotors.. done
Torsion 11-22-2013 03:57 PM
I took them to my local O'Reilly auto parts. They turned them for $15 each. They seemed to turn out okay, to the eye... if they don't wobble then I'll be very happy.
