-   -   Anyone here tuned thru AED? (http://www.dfw50s.com/showthread.php?t=3281)
toomnymods 12-09-2013 08:46 AM
I'm wanting to get rid of my bama tune and go ahead and get the tuning thru AED. Who uses him here and where can I find good 93 octane gas in south arlington?
Thanks
DirtyD 12-09-2013 10:18 AM
Make the switch, and you will be happy.
As for good gas, you will get a ton of different answers and opinions on that.
I've been meaning to do some datalogging on Kroger gas to see if the timing I was pulling on Shell 93 goes away.
Some people will say that QT, Exxon, and Chevron will have the best gas, other will say bullshit, etc. So it's hard to say.
BLK2012GT 12-09-2013 10:43 AM
Brent Yager (yagermister) used or still uses AED. I would PM him if you want info on it. And the best gas is E85.
Yagermeister 12-09-2013 11:04 AM
I've used Bama for awhile and they weren't bad. A little more hp, more pep, and great customer service.
I've used AED for awhile longer than I did Bama. A lot more hp and pep over Bama, and great customer service.
If you change things on your car frequently or need to tune your car for different temperatures, track conditions, etc tune it yourself like I currently do with the SCT ProRacer Package. When I started tuning my car myself I used a VMP base tune and it was ok but with all the engine changes and trans tuning I needed, I have had to change every single parameter VMP provided to something else.
Don Yaxley, Johnathan Kelley, and Eric Wood like VMP and have had success also.
Many of the members here also use Kevin Dunn (04sleeper) here locally. He tunes on the side from his normal job and is not a shop. He does a phenomenal job and the great thing is that he is local!
rriddle3 12-09-2013 11:06 AM
Originally Posted by BLK2012GT (Post 58665)
...And the best gas is E85.
:snoopfacepalm:
BLK2012GT 12-09-2013 11:08 AM
Originally Posted by rriddle3 (Post 58671)
:snoopfacepalm:
If you don't know the joke then don't respond.
rriddle3 12-09-2013 11:12 AM
I do know the joke, thank you. That's why I responded like I did.
DirtyD 12-09-2013 11:12 AM
I'm going to join the VMP list soon. I know his tunes take awhile to get to me, so we will see once I get it.
BLK2012GT 12-09-2013 11:13 AM
:rage:
JDBishopArts 12-09-2013 11:48 AM
Get DUNN TUNED.
jng2985 12-09-2013 04:41 PM
Thanks
Jersyjoe on here just loaded a aed tune, we did a few runs and he now walks all over me "I'm stock tune".
toomnymods 12-10-2013 08:55 AM
So what's so bad about E-85? I've read it has very similar octane to using methanol injection, but safer but requires a ton more fuel.
DirtyD 12-10-2013 10:18 AM
It's a joke.
E85 will require about 30% more fuel than normal E10 gas. On a N/A application, E85 is going to do more for protecting the engine than it will to give you additional power. The big power boost won't come until you go boosted.
pohnjarker 12-10-2013 12:23 PM
I have AED, NA and FI...both great tunes and customer service is 10 times better than BAMA at least and so are the tunes...IMO.
hard to tell on the gas, it seems there are bad batches with everyone at some point. i personally use Brookshires so whoever they get theirs from.
if you throw a couple gallons of race gas in there for logging...will that help in case of a bad batch??
Grandpa 12-10-2013 12:30 PM
Originally Posted by JDBishopArts (Post 58679)
Get DUNN TUNED.
This.
