-   -   To bama tune or not? (http://www.dfw50s.com/showthread.php?t=3441)
NZERO21 01-11-2014 01:30 AM
Hi Everyone,
So I have been hearing alot of people talk about a specified tune to the coyote engine mustangs to help improve the response of the car. My question to y'all, how much of an improvement does it really make and how much do they usually cost. So far I am only familiar with the chip on the older mustangs but I know its a bit different now with the coyote engines. Typically my goal is to have 3 different tunes that I can easily select.
The following are
-Daily Driving (Gas Saver)
-Sport Driving (Confort Driving but with some kick)
-Full Race (Taking it to the track and saying...woah baby!:drool2:)
Now I also heard of other possible tunes that I can go with other than BAMA but I want to get everyone's expertise on this one. Keep in mind that this will be for a car with an automatic transmission.
(Yes I know manual is the way to go but I heard some pros in having an automatic transmission).
ALL OF YOUR IMPUT IS GREATLY APPRECIATED!.
If you know of a great place and price of where I can get a tune, I would also be appreciative. I am a working professional DJ who has worked at radio stations such as CBS radio and will return the favor with a mix of songs of your choice of course. :)
I was also thinking of adding some 3:73 gears to get a sharp response on the car but I keep going back and forth between the tune and gears.
I'll also be contributing more to the forum as I will be videotaping an install of some HID fog lights on a CS 2011 mustang. I have not been able to find one on youtube so I figured I put one out there for everyone to see.
Thanks again everyone and I look forward in reading everyone's response.
http://i675.photobucket.com/albums/v...906_161515.jpg
http://i675.photobucket.com/albums/v...906_161240.jpg
Dominic Toretto 01-11-2014 01:42 AM
I haven't actually heard a negative comment about a BAMA tune but, I do hear people claim that a dyno tune would be more "precise" to your engine. I'm still trying to figure out that one since these (and all other mass produced engines) are built on assembly lines so tolerances, clearances, materials, factory specs would all be the same across the entire engine build. Anyway again, I have neither but, have heard that a custom tune is the way to go but, nothing wrong with BAMA. Custom tunes from a shop normally run about $500.
03MachMe 01-11-2014 02:45 AM
Haven't heard anything bad about Bama tunes? Guess you don't read much. Bama is know to be the worst of the mail tunes out there. Like 29deg of timing bad
03MachMe 01-11-2014 02:47 AM
When I get a tune it will be AED Lund or Kevin
zsommer79 01-11-2014 09:55 AM
Kevin?, more info please.
I have been looking around too lately and AED and Lund both seem to have pretty good track records.
NZERO21 01-11-2014 10:35 AM
I have read around and well, some say its good and others talk about other types of tunes, and of course I also hear about the shop tune. Then I come across the Ford Racing Boss Power pack, where you get the tune, air intake, and the boss manifold to increase the hp to about 50-60 hp. So I figured I ask the experts and see what your guys take was on it. Its hard to really make the decision but thanks to your feedback I will begin further research on custom tune with a shop. I mean even American Muscle stated that they will provide free tunes for life on the Bama tune so it got me thinking.
Sounds to me that this is one to get further research since the Power Pack runs about 1k so I wanted to see if I should get the tune, inake manifold, and air intake seperately or all in one pack.
If anyone has done a tune, let us know what you though of it and share your experience.
Dominic Toretto 01-11-2014 10:36 AM
Oh wow! I didn't see that. Also keep in mind, since I am not looking to tune so I am not searching for information on that either. So the information I have seen hasn't been negative regarding BAMA. I don't imagine their tunes are that off across the board though. But that's enough to deter me from trying once, yikes. Don't suppose you might have a link to that particular thread would you?
Dominic Toretto 01-11-2014 10:38 AM
From what I have read, Lund is the best.
rriddle3 01-11-2014 11:08 AM
Each of us that has a tune will swear that company is the best and that's why we went with it. There are several good ones out there without a nickel's difference between them.
Since you have an automatic I recommend not changing the rear gear ratio from factory. The transmission gearing for your first two gears are plenty low already. Ford made an impressive set-up with the auto trans system.
rlhay2 01-11-2014 11:34 AM
I do not have a Coyote based Mustang, so take this with a grain of salt.
Any tune is only as good as the customer service and after-sale support.
When making this decision, there is no such thing as too much information.
My experiences with mail order tunes is exactly why I appreciate my relationship with local shops!! Strongly consider fostering a relationship with a local entity before you go mail order.
But if you insist on using a mail order tune: VMP > Lund.
This is primarily due to BJ's level of customer support.
JDMLOL 01-11-2014 11:34 AM
Opinions and attitudes towards Bama will change depending on who you talk to. These cars used to have issues with cylinder eight taking a shit. Some say in the earlier days of the coyote that people with Bama tunes had an increased likelihood of this issue and the tunes could cause other issues as well. Others will say the number eight issue was because of a shitty factory tune that could cause a too lean condition in cylinder eight and an aftermarket tune would correct the problem. So there are a lot of mixed opinions on the matter. I don't care because Bama now stands behind their tune with a warranty. If and when I go forced induction I'll change to someone with more experience with FI but for now I have no issues with my Bama tune.
re-rx7 01-11-2014 11:46 AM
Ive had a Bama tune for quite sometime and no problems. If you just have simple boltons a mail order tune is just IMO.
Darkhelmet22 01-11-2014 12:33 PM
My car runs fine on my bama tune. I'm going to do some data logging on my car but I'm not getting bent out of shape on all timing comments.
NZERO21 01-11-2014 01:29 PM
That is some great feedback guys. All information is greatly appreciated and that is the reason we have forums. To get the experience from one another and help each other out. So here is a simple video explaining the bama tune and the Boss Intake. I'll try to see the information regarding the tune but I like all information posted here. I think it will be helpful for those who will be or are thinking of pulling the trigger on the tune.
re-rx7 01-11-2014 01:32 PM
What vid?
