-   -   Aeromotive Stealth Fuel Kit- A1000 (10-14 GT) (http://www.dfw50s.com/showthread.php?t=3568)
BV600 01-29-2014 08:38 PM
http://aeromotiveinc.com/products-pa...tealth-system/
Anyone heard anything about it?
Crimson600+HP 01-29-2014 08:55 PM
http://www.youtube.com/watch?v=T4x2NgRSM7o
This is StangTV or PowerTV where they put it on a 5.4L KB supercharged and it picked up 40HP with the same pulley and handled more after a pulley swap.
BV600 01-29-2014 09:07 PM
Thanks there is actually two
This one supports more power. Its the cheapest setup I've seen where you just add a return line and regulator.
toomnymods 01-30-2014 04:18 AM
aeromotive makes some awesome stuff.. I'll probably use this kit with my setup, I had a a-1000 external pump on my turbocharged titan and my whole fuel system was aeromotive with a 10An feed to the Aeromotive FPR then t'ed to 2 8An lines to the fuel rails then a single 6an return to my fuel cell.
Fuel fitting costs add up very quick. Stainless braided hose is hella expensive too. Think i spent just at 3k doing it with upgraded injectors.
pohnjarker 01-30-2014 11:58 AM
I knew your name sounded familiar...i've seen you on titantalk before...you had a white one IIRC. it was pretty badass.
that youtube video was cool, nice setup. i'd love a new return fuel system but i think i'd forge the bottom end and upgrade the oil pump gear first. my JMS BAP will be more than enough until then...its a quality bandaid!
BV600 01-30-2014 02:24 PM
The only reason Im looking at fuel before shortblock is I want to run E85. With the current issue of numerous (not all) stock pumps failing on E85 w/ BAP. I want to fix that issue first. I will be happy with mid/upper 600s on E85
five.slow 02-01-2014 05:46 AM
Haaa on e85 I made 727. You won't have a issue making your goals man.
pohnjarker 02-10-2014 01:47 PM
i hear that...i make almost mid 600s on 93 so with E85, you should do much better. sounds like a beast setup you're going to have.
