-   -   Passing State Inspection (http://www.dfw50s.com/showthread.php?t=3771)
BLK5.0MSTG 03-03-2014 11:06 PM
My 2012 will not pass State Inspection. I have 2 O2 sensors coming back not ready. Ford has replaced all of the O2 sensor, the catalytic converters and the ECM. There is no tune on the car. I have Pypes axle back exhaust and X pipes. Ford is now saying they want to put the sound tube and stock exhaust back on.
What I want to know is how many if you have removed the sound tube and have an after market exhaust and passed state inspection? I want to go back to Ford and give them some numbers to prove their wrong.
JDMLOL 03-03-2014 11:16 PM
If everything from the cats/ rear o2's forward is stock, you should have no problem. Sound tube? Really? It's a novelty, shouldn't matter if it's capped or not.
downtime! 03-03-2014 11:54 PM
Sound tube has exactly zero to do with the 02's not being ready. After market cats can be a pain but they can be made to pass.
Go here - http://www.obdii.com/drivecycleford.html and do everything exactly as stated, and try to plan your route so that you end up at the inspection place when done. It's a PITA, but it works.
BLK5.0MSTG 03-04-2014 12:54 AM
Thanks. I've done Fords drive cycle. I've done the Ford Racing drive cycle. I've done the Shelby drive cycle. This has been going on for over a year. I had to get a State Waiver for the last inspection and Ford still can't figure out what's wrong.
fordplay 03-04-2014 08:45 AM
What is this state waiver???? Contact aed you can get a tune that forces the o2 sensors to be ok
JDMLOL 03-04-2014 09:47 AM
That can legitimately be done? I thought that could only be done in the movies. Lol.
DirtyD 03-04-2014 10:13 AM
Jan, have they tried changing out the O2 sensors multiples times? Could it possibly be a problem with the wiring harness?
46Tbird 03-04-2014 11:12 AM
State waiver just means that you have spent X amount of dollars in an attempt to get the car to pass an emissions inspection, but it still fails. The waiver allows you to get an inspection sticker if the vehicle is able to pass a safety inspection.
http://www.txdps.state.tx.us/rsd/vi/...Extensions.htm
fordplay 03-05-2014 08:04 AM
It's true ... here is your link
http://www.svtperformance.com/forums...-aed-tune.html
I can't say it works... but as I have no cats now... you can bet if bama does not do this.. I'll be switching in the coming months
Mrjeremyt 03-05-2014 10:33 AM
It's a 2012? Just safety only the state inspection, OBD isn't required...
