-   -   Weird knocking noise? (http://www.dfw50s.com/showthread.php?t=3776)
NikkiDawson 03-05-2014 11:55 AM
So last week I started hearing a strange knocking noise whenever I turn or go over bumps. Its only on the left back side that i hear it. Any ideas on what it could be?
Dominic Toretto 03-05-2014 01:32 PM
How loud is it and is there a pattern of the knock sound exactly?
El_Tortuga 03-05-2014 02:25 PM
Got to climb under the car, could be lots of stuff. For me, I had to retighten the sway bar end links, and once the PHB adjuster nut backed off. Loctite is my friend now
NikkiDawson 03-05-2014 02:57 PM
Its not repetitive, and it doesnt do it every turn or bump. It very random. And its loud enough for me to question what it is when listening to the radio. Ive checked my sway bar already, im pretty sure its not that.
Zeek 03-05-2014 04:07 PM
Isn't there a TSB for somthing like this?
NikkiDawson 03-05-2014 04:11 PM
Wasnt aware.
JDBishopArts 03-05-2014 05:34 PM
Check and make sure the axle weights are tight. Also, what are your mods?
NikkiDawson 03-05-2014 05:55 PM
Ill check that out to see. I havent added any mods besides flowmasters and wheels.
Crimson600+HP 03-05-2014 11:39 PM
May also be time to grease the sway bar bushings also
NikkiDawson 03-06-2014 12:36 AM
Thanks for helping guys!!
fordplay 03-06-2014 09:23 AM
I have had to adjust my flowmaster axle backs they were causing an occasional rattle and knock.. drove me crazy till I saw the witness marks.. A little force applied and problem solved..
Bacadiesel 03-06-2014 11:47 AM
How many miles on car? Could be a bad shock maybe.
JDBishopArts 03-06-2014 12:59 PM
x2. That was my next suggestion. My axle weights came loose at around 15k miles. Took me forever to figure it out. I started banging things with a rubber mallet and was like AHHHhhhh when I hit the weight. haha
NikkiDawson 03-06-2014 06:55 PM
Theres 20,000 miles on it. I havent heard it for a couple days. I thought it might be my mufflers, it makes the same sound when idling. Also thought it could be the shock, i bought it preowned. I was planning on putting the eibach strut and shock kit on it.
Bacadiesel 03-06-2014 11:45 PM
Hope it's something simple. Maybe first owner had suspension mods and took them off to sell the car, and they could of left something loose. Maybe just recheck all the bolts for control arms. Could be exhaust though.
