-   -   Stock shifter issues (http://www.dfw50s.com/showthread.php?t=3987)
Soulowd 04-12-2014 08:31 AM
Hey guys has any of you ever had any problems with your stock shifters? Nine times out of 10 whenever I am shifting into forth under heavy load it just like I'm hitting a wall and cannot get it in properly. I have heard from several people that these shifters are hit or miss. I never had any issues with my 2011 shifter. I guess I'm going to have to pick up a mgw or Barton.
donutninja 04-12-2014 09:15 AM
I've heard the same thing and I think it feels a little sloppy though way better than my old Maxima did. I always have issues with 3rd.
5PointSlow 04-12-2014 09:49 AM
I have the JHR line, shifter bracket and Tilton TSR-1 brake/clutch fluid. everything else is stock. no issues shifting at all.
fordplay 04-14-2014 07:07 AM
Doughnut, with third, don't ham fist the shifter into 3rd, open palm, diagonal nudge, it goes like butter, when you force it we have a tendency to push down and it changes the angle and you bind going into gear, honestly almost every gear change for me is open handed, when I'm putting around all I use it 2 fingers to shift, let it do the work for you
Darkhelmet22 04-14-2014 10:14 AM
Mine never wanted to go into 4th or 5th on high rpm shifts. The MGW makes a ton of difference but I would also recommend the whiteline trans bushing and a good fluid. Ive heard mixed reviews on replacing the clutch line and removing the clutch pedal return spring.
PCB 04-14-2014 10:31 AM
I did Barton w/bracket and the transmission bushing and have never had problems.
DirtyD 04-14-2014 10:37 AM
my car is stock shifter + Barton 2-post bracket, Whiteline trans bushing, JHR/JPC stainless clutch line, motul rbf600 fluid. no issues lately with shifting under WOT
NAVAG 04-14-2014 11:15 AM
MGW if you want to do track. Barton good enough for daily driving. Sometimes I have a hard time with 3rd and 5th and also down shifting into 4th. Thinking about buying a Barton Bracket.
Grandpa 04-14-2014 11:37 AM
Yes. Put an MGW in and it fixed the issue. The stock shifters are just really sloppy and vague.
El_Tortuga 04-14-2014 01:28 PM
Happy with the Barton c/w 2 post bracket and white one bushing. The track pack 3.73s and shorter tires mean I'm working it a bunch to get around the course.
TwoQuack 04-14-2014 02:52 PM
If you listen to someone who eats their own dogfood, chances are you won't go wrong.
The guys at Vorshlag know what they're talking about when it comes to these Mustangs. They've got one there with which they've won many events and hold records in certain tracks with it. And they've got many Mustang customers. To me, if you're doing that well on the track with it, I'll take that advice above any others.
This being said, I'd bought an MGW and asked if they'd install it for me. He said with their race car they have the stock shifter with the Whiteline bushing, which they sell, and the Steeda Shifter Base Bushing. He advised me to install those 1st and see how they performed. I've got an appointment there this week to get those installed. If it goes well I'll have an MGW for sale, in case you still want to go that route.
My 2 dracmas. If it has to do with suspension and performance, ask Vorshlag before buying into anyone else's story. Chances are Vorshlag will give you the best recommendation.
GreenGravity 04-14-2014 08:22 PM
I'm going to order the base brace before anything els due to quacks recommendation I have seen many others state it's the reason for sloppy shifts and reduces your chances of a miss.
fordplay 04-15-2014 07:30 AM
Woo hoo stock shifter for the win!!! Doesn't the new Barton come with a new base? Along with the white line trans brace.. I'd still consider the Barton bracket.. Instead of the stock zip tie piece
Crimson600+HP 04-15-2014 07:41 PM
Great advice. I ask for advice from a lot of people too, but I usually take most advice with a grain of salt unless they have the experience that I trust.
If you end up selling the MGW...let me know.
Soulowd 04-16-2014 04:49 PM
1 Attachment(s)
Installed Whiteline Positive Shift Kit today and it is awesome! I took the stang out to an empty road and gave it 4 hard runs and it shifts waaayyy better. No more getting locked out of 4th just like shifting through butter on a hot day. And it was only 35$ @ Vorshlag. Took maybe 10-15 minutes to install.
